Old 01-25-2015, 11:52 AM   #1
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Ecutek map with speed limit?
Since we can have up to 4 maps selectable via cruise control stalk, is it possible to include say a default "valet map #1" that has a speed limit (e.g. 25mph) set for that map only?
Fizz is offline   Reply With Quote
Old 01-25-2015, 05:45 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
You could have per gear rev limits set per each map mode. Without my laptop I can't confirm whether speed limits are possible.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Fizz (01-26-2015)
Old 01-27-2015, 02:34 PM   #3
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@DeliciousTuning do you know if it's possible to set speed limit on the map?
Old 01-28-2015, 02:33 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
I've looked through the maps and see nothing to govern the speed, however you could set up an ignition map to retard timing at a set speed,a bit like creating a soft limiter.
Alternatively use the per gear setup so that each gear is limited to a lower RPM to create a "speed limit". Something like:
1: 5000
2: 3500
3: 2700
etc
.: Stealth 86 :.
Kodename 47 DJ:
Fizz (01-28-2015)
Old 01-28-2015, 09:13 AM   #5
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
A rev limit would be more desirable. If someone gets in your car and can't rev passed 3000 rpm they will never try to see how fast it can go. On my mr2 my plan was if i had to have someone i didn't know drive it, I would lower the boost setting in the ecu to lower then the waste gate so the ecu will think that something is wrong with the boost controller and cuts fuel when it sees higher boost then the setting. I tried it once and it works good.
Toyota John is offline   Reply With Quote
Old 01-28-2015, 11:32 AM   #6
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It doesn't matter if the car is set to limit RPM's to 3K or MPH to 25, I never ever let my car in valet. They will find a way to try and abuse it if they want.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
D_Thissen (01-28-2015)
Radar detectors, worth it if I usually just go over 10mph above speed limit? tracerit Electronics | Audio | NAV | Infotainment 44 01-14-2019 04:31 AM
Roebling Aug 16,17 60 Car Limit Deep Six Southeast 5 08-08-2014 03:26 PM
2013 SCION FR-S 6 SPEED 19'WHEELS GREDDY EXHAUST ECUTEK TUNE LOW MILEAGE hayleybeaners Cars for Sale/Trade 1 05-08-2014 09:15 AM
No Limit Motorsport LeeMaster User/Vendor/Sponsor Reviews, Feedback, Comments 6 05-17-2013 12:16 AM
Rev Limit Acid18 Scion FR-S / Toyota 86 GT86 General Forum 36 01-13-2013 04:55 PM
