SPC Camber Bolts
Anyone running the SPC front camber bolts? Are they any good? Do they work with the stock struts?
/scion
Drives: '13 86 M/T
Yes.
Yes. Yes. |
Killed Scion
Drives: 2013 FR-S Whiteout
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
Drives: frs
Also yes, yes, yes
Drives: GT86
I have them, they're ok (only got 1.1 of camber), yes
Drives: 2005 Toyota Camry
Yes to the yes.
Ex-MR2 owner
Drives: Scion FRS
Yes! Found that my front tires are gripping more at Auto X after I installed them. Got about -1.7 of camber with 14mm bolt for the top hole instead of the 16mm.
Drives: 2013 Raven FR-S
I've been able to get up to -2.5 using the SPC bolt on bottom and Subaru OEM 14mm bolt on top. I'm dropped almost an inch though, so that helps some too.
Drives: 2013 Scion FR-S, 1993 Lexus SC300
This is pretty much exactly what I am doing right now. Fine adjustment is not easy, but I just have it set to the maximum amount available anyways....
#10 |
Drives: 2013 FRS
#11 |
Drives: GT86
Just managed to get my camber up to -2.3 degrees by installing the old 14 mm bolt the SPC bolt replaced.
#12 |
Drives: '13 FR-S
Love them. Stock suspension with fairly sticky PSS tires. The grip difference from factory while autoX-ing is astonishing.
| FS: HVT Non-raising camber plates & WL camber bolts | trippinbillies40 | Brakes, Suspension, Chassis | 1 | 05-16-2015 09:00 PM |
| Camber bolts: Max camber tricks | bfrank1972 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 06-03-2014 10:01 AM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
| Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
