Old 10-29-2015, 11:40 AM   #1
ChrisP
SPC Camber Bolts
Anyone running the SPC front camber bolts? Are they any good? Do they work with the stock struts?
ChrisP is offline   Reply With Quote
Old 10-29-2015, 11:42 AM   #2
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Yes.
Yes.
Yes.
LOLS2K is offline   Reply With Quote
The Following 2 Users Say Thank You to LOLS2K For This Useful Post:
Calum (10-29-2015), ChrisP (10-29-2015)
Old 10-29-2015, 11:59 AM   #3
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Originally Posted by LOLS2K View Post
Yes.
Yes.
Yes.
I run them. Agree with above.
Instagram: trevor.parque
ChrisP (10-29-2015)
Old 10-29-2015, 12:16 PM   #4
twag4
Drives: frs
Also yes, yes, yes
twag4 is offline   Reply With Quote
The Following User Says Thank You to twag4 For This Useful Post:
ChrisP (10-29-2015)
Old 10-29-2015, 04:13 PM   #5
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
I have them, they're ok (only got 1.1 of camber), yes
Cartman is offline   Reply With Quote
The Following 2 Users Say Thank You to Cartman For This Useful Post:
ChrisP (10-29-2015), strat61caster (10-29-2015)
Old 10-29-2015, 07:02 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Yes to the yes.
ChrisP (10-30-2015)
Old 10-30-2015, 02:02 AM   #7
mb_
Ex-MR2 owner
Drives: Scion FRS
Yes! Found that my front tires are gripping more at Auto X after I installed them. Got about -1.7 of camber with 14mm bolt for the top hole instead of the 16mm.
mb_ is offline   Reply With Quote
The Following User Says Thank You to mb_ For This Useful Post:
ChrisP (10-30-2015)
Old 10-30-2015, 09:29 AM   #8
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I've been able to get up to -2.5 using the SPC bolt on bottom and Subaru OEM 14mm bolt on top. I'm dropped almost an inch though, so that helps some too.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
ChrisP (10-30-2015)
Old 10-30-2015, 11:03 AM   #9
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
This is pretty much exactly what I am doing right now. Fine adjustment is not easy, but I just have it set to the maximum amount available anyways....
FrX is offline   Reply With Quote
The Following User Says Thank You to FrX For This Useful Post:
ChrisP (10-30-2015)
Old 10-30-2015, 04:58 PM   #10
Cop
Cop's Avatar
Drives: 2013 FRS
https://www.google.com/search?q=spc+...w.ft86club.com
Cop is offline   Reply With Quote
Old 11-08-2015, 10:22 PM   #11
Cartman
Cartman's Avatar
Just managed to get my camber up to -2.3 degrees by installing the old 14 mm bolt the SPC bolt replaced.
Old 11-08-2015, 10:42 PM   #12
CatDaddysBBQ
Drives: '13 FR-S
Love them. Stock suspension with fairly sticky PSS tires. The grip difference from factory while autoX-ing is astonishing.
CatDaddysBBQ is offline   Reply With Quote
The Following User Says Thank You to CatDaddysBBQ For This Useful Post:
eurominican (05-06-2016)
FS: HVT Non-raising camber plates & WL camber bolts trippinbillies40 Brakes, Suspension, Chassis 1 05-16-2015 09:00 PM
Camber bolts: Max camber tricks bfrank1972 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-03-2014 10:01 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
