Old 10-29-2015, 12:40 AM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile OpenFlash Tablet: OTS v2.070 released (F20P ROM support)
Hi guys,
New OTS map folder has just been released and is now available to download HERE
Please read the change log in the included Release Notes file. It says:
0/28/15
v2.070
-Added full tune and XML support for ZA1JF20P Calibration ID.
So this update only applies to you if you have this calibration ID. If not, you can ignore this message
Cheers,
shiv
Old 10-30-2015, 10:47 PM   #2
cookiesowns
Drives: WRB BRZ Series.Blue
Shiv, does this release fix the U whatever cluster communication failure code? I noticed the new D00C rom with LC/FFS does not have this code disabled, really annoying.. as each time I plug/unplug the OFT when ignition is on results in that code and the car going into limp mode. Clearing the code resets all my fuel trims too
cookiesowns is offline   Reply With Quote
Old 10-31-2015, 12:21 AM   #3
ryoma
ryoma's Avatar
from what I understand, you don't want to plug in ANY OBD2 device when the car is already running as it will mess with the electronics.
Old 10-31-2015, 01:07 AM   #4
steve99
As above best option is not to unplug/plug obd devices when engine running. Seems to cause more dramas with auto trans.
The codes to disable in tune would be P0700 (auto trans module communication)and maybe U0155 (dash cluster communication)
is it those codes your triggering ?
Old 10-31-2015, 11:31 PM   #5
cookiesowns
Yes, it's triggering the U0155 code. It was previously disabled in the last release of the D00C, I guess they re-enabled it for whatever reason?
OpenFlash Tablet: OTS v2.069 released (FFS/LC for F00C roms) Shiv@Openflash Software Tuning 9 12-29-2015 05:51 AM
End of Summer Sale! OpenFlash tablet+OpenFlash Header+OEM Gaskets Shiv@Openflash Engine, Exhaust, Bolt-Ons 2 10-01-2015 06:25 PM
OpenFlash Tablet: OTS v2.068 released (FFS/LC for D00C roms) Shiv@Openflash Software Tuning 13 09-19-2015 06:18 PM
FS: New Openflash Tablet, New Openflash Header, New Ducktail Spoiler, NewCrawford BPB FT86POWER Engine, Exhaust, Bolt-Ons 5 09-16-2015 03:26 PM
OpenFlash Tablet firmware 1.26 (Digital Gauges, WB Support, BPB Maps, Sale, Oh My!) Shiv@Openflash Engine, Exhaust, Bolt-Ons 79 05-14-2014 04:34 AM
