Old 10-26-2015, 11:24 AM   #1
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Fitment with -2 Camber and 1" Drop 18x9.5?
Morning All,
Please forgive me.. I've done plenty of searching but am still not confident in wheel/tire fitment and would rather ask than make a mistake:
I'm looking into Ambit RE02 18x9.5 (+38) or 17x9 (+38) wheels. I'm running -2 camber in both front and rear, with a 1" drop on lowering springs.
Should I expect any issues with fitment? Searching seems to suggest that -2 camber will help clear these things... but I'm just having trouble finding my exact setup.
Thanks in advance!
ajcarson11 is offline   Reply With Quote
Old 10-26-2015, 12:31 PM   #2
8R6
8R6's Avatar
Drives: FRS
depending on tire size, you might rub a little bit against the spring or spring perch.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
ajcarson11 (10-26-2015)
Old 10-26-2015, 12:35 PM   #3
ajcarson11
Would rubbing increase with additional negative camber (that would seem to make sense... but just checking)?
What tire size would you recommend if going with 17x9? 245/40/17?
Thanks!
Old 10-26-2015, 12:39 PM   #4
8R6
8R6's Avatar
Drives: FRS
Thanks!
you might get too close if you have more -2 deg camber up front. (rears are fine).
im basing my answers on my old setup when i had 17x9 +38 with 245/40/17 and lowered 1" on springs with -1.5deg camber (camber bolts).
with this setup i had zero rub, but i still only had a like 4-5mm space between my tire and the oem spring perch. if you can squeeze out -2deg camber, you should still be clear but itll just be even closer.
Old 10-26-2015, 01:29 PM   #5
ajcarson11
Great. Thanks for your response. I guess if worst comes to worst I can dial back the camber, or throw in a 5mm spacer!
FS: Advent OTOMF1 Multimedia/Navi - Toyota "OEM" fitment corry29 Audio/Visual, Electronics, Infotainment, NAV 1 10-27-2015 12:48 AM
235/35 On 18x9 +35 with -1.75" Drop Springs...Possible? ShaneLindley Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-06-2015 01:45 AM
18x9.5 +45 fitment Wilson15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-05-2014 07:49 PM
Drop and camber. WillBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-09-2014 06:31 PM
New "Drive Clean" on wheel repair and fitment SkAsphalt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-10-2013 05:59 PM
