Old 01-27-2013, 01:36 PM   #1
WillBRZ
WillBRZ's Avatar
Drives: 2013 BRZ Limited 6MT GBS
Exclamation Drop and camber.
I've been trying to find this info for a while and I keep finding different answers. Can people who actually have the drop and have gotten aligned with oem camber arms chime in?
How much did you drop?
How much F/R natural camber did you have AFTER aligning with the drop?
What springs/coils did you use?
Toe in spec?
Caster in spec?
How are you liking the drop/spring/coil choice?
If this info is out and scattered that's fine I think it would be a lot easier for me and other people to find this info in 1 thread.
My old car would freak out with drops and you would need f/r camber kits from a 1/2 inch drop lol
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT
SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist
WillBRZ is offline   Reply With Quote
The Following User Says Thank You to WillBRZ For This Useful Post:
SP86 (02-05-2014)
Old 01-27-2013, 03:05 PM   #2
636
636's Avatar
Drives: '23 CWP BRZ
Toe in spec?
Caster in spec?
I haven't gotten an alignment yet, since I still want to go a little bit lower, but I'm 100% there is NO rear camber adjustment on OEM camber arms! I'll re-edit this when I get my alignment.
636 is offline   Reply With Quote
Old 01-27-2013, 03:07 PM   #3
WillBRZ
WillBRZ's Avatar
I have heard that. I just want to know what the natural camber is. On my old car with my 1.6inch drop natural camber was -2 front and -2.2 rear but rear toe was out of spec so I got camber arms and toe bolts and got everything back into spec. A little camber is nbd but you don't want any toe.
Old 01-27-2013, 03:26 PM   #4
whataboutbob
AutoX-10/10ths every run
20mm
1 3/8 deg neg (ft), 2 deg neg (rear)
RaceCompEngineering Springs
Toe in spec?
0 deg
Caster in spec?
8 deg pos w/Whiteline anit-dive/caster bushing on front LCA
Great so far for DD. My first AutoX is Feb 3, that'll be the real test.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
phm14 (04-24-2020)
Old 01-27-2013, 03:32 PM   #5
WillBRZ
WillBRZ's Avatar
20mm
Toe in spec?
0 deg
Caster in spec?
Very nice! This is with aftermarket camber arms right?
Old 01-27-2013, 03:34 PM   #6
whataboutbob
Thanks!
Assuming you are talking about the rear, no mods there except the springs.
Build thread:Here
Old 01-27-2013, 03:36 PM   #7
fledonfoot
Drives: Asphalt FR-S
I just dropped mine on the hotchkis sport springs.
1" drop after it settled... No crash bolts or anything, ended up with -.7 degrees front and -1.8 rear. The rear was not adjustable.
fledonfoot is offline   Reply With Quote
Old 01-27-2013, 03:36 PM   #8
WillBRZ
WillBRZ's Avatar
Thanks!
Oh great!
Old 01-27-2013, 03:37 PM   #9
WillBRZ
WillBRZ's Avatar
how about toe?
Old 01-27-2013, 03:43 PM   #10
fledonfoot
how about toe?
Set to 0
Old 01-27-2013, 03:45 PM   #11
WillBRZ
WillBRZ's Avatar
Set to 0
Awesome. So I should be pretty save with a 1-1.5inch drop without camber or toe arms.
ProjectD (01-29-2013)
Old 01-27-2013, 03:48 PM   #12
fledonfoot
Completely. The hotchkis and RCE Yellows play nice with the stock dampers too.
Old 01-27-2013, 04:14 PM   #13
djliquidsteele
Drives: Scion FR-S
I plan in getting the @RacecompEngineering BRZ Lite package in a few weeks. This includes the front camber bolts and rear camber bushings. With this in mind, what is the optimal alignment for mostly DD with a HPDE a month.
Thanks
djliquidsteele is offline   Reply With Quote
Old 01-27-2013, 04:16 PM   #14
WillBRZ
WillBRZ's Avatar
Thanks
I've always tried to be in oem spec as far as alignment goes. only time I would think to run a ton of camber is to fit wheels or drift, and would only play with toe settings if it was a track only car. No need to trash ur tires if your DDing ur car.
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 07:06 AM
camber kit? iHeartmyFR-S Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 02-15-2013 08:30 PM
Who is going to buy the FRS DROP DROP Shop? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 1 10-18-2012 06:45 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 07:51 PM
Camber arms? skoodge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 06-24-2012 11:09 PM
