Old 10-23-2015, 11:09 PM   #1
username404
Drives: 2013 BRZ Limited GB 6MT
Cant find LC setting on RomRaider
Need help with LC for OFT for my '13 BRZ 6MT
Current Engine setup
OFT + UEL OFH + Crawford BPB with 93 Stg 2 UEL BPB MAP
Downloaded the RomRaider and added definition for my JA00C but can't find the LC setting anywhere.
Trying to add LC for
93 Stage 2 UEL BPB
E85 Stage 2 UEL
Please help! Thank you!
username404 is offline   Reply With Quote
Old 10-23-2015, 11:32 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Did you use the definitions downloaded from openflash?
If you didn't, you need to delete all your definitions in romraider and delete any roms you've edited right now.
Old 10-23-2015, 11:44 PM   #3
username404
Nope, I used the ones from RomRaider site.
Also, someone told me that v2.069 has LC built-in at 5Krpm. My current map is V2.066, and V.10 Beta for the Stage 2 BPB.
Old 10-23-2015, 11:50 PM   #4
username404
Yep, It works now! I found the folder with updated definitions from OpenFlash and v.2069
Old 10-23-2015, 11:56 PM   #5
username404
Is that is? Update the RPM DELTA to 3600?
Old 10-24-2015, 08:49 AM   #6
denso
Drives: 86
Yes, your LC is Redline (7450?) - LC RPM Delta (3600) = 3850rpm.
denso is offline   Reply With Quote
The Following User Says Thank You to denso For This Useful Post:
username404 (10-25-2015)
RomRaider itsjustdavep Software Tuning 34 03-18-2017 04:48 AM
Romraider Down? RustySocket Software Tuning 7 10-02-2015 10:28 AM
dbw romraider mod RaineyStar Software Tuning 1 06-05-2015 12:53 PM
need some help with romraider logger toyotaAlex Software Tuning 2 07-06-2014 08:07 PM
RomRaider XML definitions. wparsons Software Tuning 9 03-25-2014 12:24 PM
