Old 10-19-2015, 05:35 PM   #1
Ehokana
Drives: 2016 FRS
Second Cat Heat Shield With Catless Front Pipe?
Hey guys, I just put did an Invidia q3000 exhaust and catless front pipe on my 2016, and was wondering if it required a heat shield as the original second cat had mounted. There is not a mounting point on the Invidia as on the stock cat, so I assume the shield is not re-used.
Does anyone have some insight on this?
Ehokana is offline   Reply With Quote
Old 10-19-2015, 05:37 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
The heat shield is for a cat. Cats get hot.
jawn is offline   Reply With Quote
Old 10-19-2015, 06:07 PM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
The OEM overpipe has it's own heatshield also, so I think it's a valid question.
But yeah, no heat shield is needed with aftermarket frontpipe.
Originally Posted by humfrz
I'm old and lazy
Ehokana (10-19-2015)
Old 10-19-2015, 06:10 PM   #4
jawn
jawn's Avatar
That's fair. I initially thought this thread was going to be about fitting the OEM heatshield back on to try and beat an emissions test.
Old 10-19-2015, 06:34 PM   #5
Ehokana
Drives: 2016 FRS
Thanks guys- I figured that was the answer since the catless front pipe opens up so much space in the tunnel, where the stock cat was pretty tight against the side of the tunnel and tranny
Old 10-19-2015, 06:35 PM   #6
Ehokana
Drives: 2016 FRS
Nah, I won't have an emissions test for a couple of years- at that point I'll just swap the stock front pipe back on
Tomei uel headers w/o heat shield hahaman86 Engine, Exhaust, Transmission 12 10-30-2014 12:25 AM
Seibon TS hood heat shield texasbound972 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-09-2014 12:08 PM
Racer X Fabrication heat shield, help us to help you Jeff@Racer X Fab Engine, Exhaust, Transmission 31 07-17-2014 10:20 AM
WTB: Front pipe cat heat shield Tim_Asphalt_FRS Engine, Exhaust, Bolt-Ons 4 09-19-2013 01:52 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 07:37 AM
