Drives: 2013 limited brz, skyline R33 gtst
crank timing marks?
A friend took his right side timing chain off and is now struggling the timing marks. The cams have the little marks and the chain has the 2 pink for the cams and the black link for the crank but cant see the markings on the crank. New to boxer motors. Where is the crank mark?
Thanks |
Drives: 2014 SWP BRZ, MT
The crank mark is on the timing gear itself that drives the two chains, looks like a half moon dimple if I remember correctly. You have to remove the piece that goes over the crankshaft that allows the crank pulley to bolt up. It was pretty silly for me since I used the pulley to rotate the crank and had to keep installing and removing it to get it in place.
It's a bit hard to describe, I recall that it's on the gear sprocket itself, not the shinier flat machined face that the crank pulley/oil pump driver part goes on. Edit: This is a picture out of the FSM.
The answer is racecar. Always.
| Second time crank seal leak possible crank walk | kiichiro | Engine, Exhaust, Transmission | 13 | 09-19-2018 06:57 AM |
| Help on Swirl marks on my new FRS | xcooperx | Southern California | 9 | 02-10-2015 06:36 PM |
| Marks on car | ID86 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 34 | 12-26-2013 11:43 AM |
| swirl marks | jarviz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 31 | 07-12-2012 09:33 AM |
| Explorer EcoBoost gets low marks | Exage | Other Vehicles & General Automotive Discussions | 4 | 08-30-2011 08:52 PM |
