Old 12-24-2013, 09:08 AM   #1
ID86
Drives: FRS
Marks on car
I just took delivery of my brand new FRS. However, I'm having a little problem..
Because I took delivery on a rainy/cloudy day, I couldn't see the details really well..
I have it on both sides of my car. Does anyone know if it's okay to use hand soap to try to remove it?
It might be a bit hard to see.
ID86 is offline   Reply With Quote
Old 12-24-2013, 09:12 AM   #2
whaap
whaap's Avatar
Just my thought. If you risk messing things up you would be in trouble. I would take it back to the dealership and point this out to them as a flaw. Let them correct it and if a mistake is made let it be theirs and not yours.
whaap is offline   Reply With Quote
Old 12-24-2013, 09:15 AM   #3
ID86
Drives: FRS
Quite a drive from my house to there.. Don't really wanna go there unless it's an emergency.. Is it okay to use hand soap on these car paint?
Old 12-24-2013, 09:18 AM   #4
JSanders
FR-S Newb
JSanders's Avatar
Are they straight lines? I had some very similar lines on my roof from the protective film used in transport. If that is the case I strongly recommend that you DO NOT try to scrub them off. Only thing you'll do is leave scratches in the clear coat trying. Go get a clay bar kit and focus on that area. It will easily pull the contaminants from the paint and not destroy the finish if used properly.
"Driving is the synchronization of vision, analysis, and movement. It is an art form." -Unknown
JSanders is offline   Reply With Quote
Old 12-24-2013, 09:18 AM   #5
CBR600RR
Drives: Raven Black
Edit: Ninja'd ^
that looks like glue residue from the white protective film they put on cars int he factory. get your car detailes and I bet those marks will be gone.
Old 12-24-2013, 09:19 AM   #6
ID86
Drives: FRS
Yea.. What im thinking is this too.
[ame="http://www.youtube.com/watch?v=10jfLk2vWEI"]BRAND NEW 2013 Scion FR-S 10 Series PRE-PDI Start up and walk around - YouTube[/ame]
at 1minute mark
And yes, the lines are super straight. Do you guys it will work if I use a microfiber cloth and use some hand soap and water to remove it without damaging the paint?
Old 12-24-2013, 09:33 AM   #7
gily25
Drives: Silica BRZ 6MT
You seem stuck on this hand soap idea. I wouldn't use hand soap. Clear handsoap is great for cleaning up cloth items with minimal water but I think that you'll just end up scratching the car because it's simply not sudsy enough to lift on the dirt that is around these glue lines.
Get yourself some car wash soap, microfiber mit, 2 buckets (google two bucket method), some microfiber towels to dry and head down to the local carwash. I realize that it's winter in VA but most carwashes have warm water in the spray bays and a faucet (clean water, not reused) for you to fill the buckets. Spray the car first, use the foam gun if they have it (NOT THE BRUSH), then wash the car by hand and finish with a high pressure spray. When you wash, concentrate on washing completely first, then come back and wash around those lines. Your Spring detail will clean up any scratches you pick up.
gily25 is offline   Reply With Quote
Old 12-24-2013, 09:40 AM   #8
DarkSunrise
DarkSunrise's Avatar
Yeah as others have said, that's from the protective tape. I had that too. If you don't want to wash the car in the winter, you can use some quick detailer or bug/tar remover and wipe it off using a microfiber towel.
2022 BRZ Build
2013 FR-S Build
Old 12-24-2013, 09:41 AM   #9
ID86
Drives: FRS
Cool, I'll get some of those bug/tar remover.
Just a question, I have some goo gone in my house, can I use it on those residue without damaging the paint?
Old 12-24-2013, 09:46 AM   #10
radroach
Drives: car
Hand Soap. Sir you may need to learn how to wash a car before you ruin the paint on your new FR-S.
[ame="http://www.youtube.com/watch?v=X0Sqi1lAj1A"]Audi R8 BLACKBIRD: Basic Car Wash Techniques - /DRIVE CLEAN - YouTube[/ame]
Put some rubber kitchen gloves and waterproof boots on and your hands wont get cold.
Go to Autozone. Buy some high quality car wash.
Meguiar's Gold Class or Deep Crystal Car wash or.. Do not get that wash + wax garbage. 2 microfiber mitts, 2 microfiber drying towels, and 2 buckets. One mitt use only for the body of the car, and the other mitt only use for cleaning the wheels. Spray car with water. Put soap in bucket, fill with water. Work from top to bottom. Clean a section at a time, washing off the mitt and getting new soap from the buckets after every section. Hose all the soap off the car. Dry using a couple drying towels or by driving down the street.
Do not continuously scrub an area unless necessary, the more you touch the car while washing the more you put fine scratches into the paint.
Apply wax after. You may need to check another tutorial on that.
TLDR: If you want to learn how to wash a car, hire a detailing specialist in your area to handle the initial cleaning of your car and watch him do that. I'd recommend searching for a person who specializes using Meguiar's products, (or search for any other high quality brands), and is using the newest Meguiar's DA microfiber kits etc.
Old 12-24-2013, 09:47 AM   #11
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
NO! Premium car wash only.
ntron1 is offline   Reply With Quote
Old 12-24-2013, 09:58 AM   #12
DarkSunrise
Some people say they've used goo gone on car paint (leaving it on for a short time) and say it's fine. Others have said they used it and it took off the clear coat.
Personally I wouldn't risk it on a brand new car.
2022 BRZ Build
2013 FR-S Build
Old 12-24-2013, 10:44 AM   #13
AznBRZer
Drives: 16 CBS WRX Limited
Easier to just get it detailed if you can afford it. That way, it'll get clay bar'd to remove all the contaminants from shipping as well as giving it proper protection.
AznBRZer is offline   Reply With Quote
Old 12-24-2013, 10:48 AM   #14
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
lol hand soap.
SloS14 is offline   Reply With Quote
Two vertical streak marks on windows tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 06-04-2013 09:27 AM
Windshield Wiper Marks StOpNG0x Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 05-09-2013 07:27 AM
dealer marks on windshield sitandspin Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-24-2012 11:33 AM
swirl marks jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 31 07-12-2012 08:33 AM
Explorer EcoBoost gets low marks Exage Other Vehicles & General Automotive Discussions 4 08-30-2011 07:52 PM
