Old 10-09-2015, 12:35 PM   #1
shellslinger
Drives: Whiteout FRS
Clutch Rattle at cold start
Hello,
Sorry if this has been posted before. I recently just started to experience this clutch rattle only at cold starts. When I push in the clutch the noise goes away. After about 10-15 minutes of driving the noise is completely gone. Any advice?
Btw- I am running motul gear oil.
Thanks
shellslinger is offline   Reply With Quote
Old 10-09-2015, 12:36 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by shellslinger View Post
Hello,
Thanks
Noise from the shifter?? If it comes from the shifter itself then there is a TSB for that.
Old 10-09-2015, 12:42 PM   #3
shellslinger
Definitely not gear shifter. The noise occurs when it's at a cold start in neutral. It's coming from under the hood. Noise goes away when driving.
Old 10-09-2015, 12:53 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Hmm no idea then, sorry :/
Old 10-09-2015, 12:54 PM   #5
shellslinger
All good, thanks for the input though.
Old 10-09-2015, 03:24 PM   #6
strat61caster
strat61caster's Avatar
Not unheard of, unlikely to be a problem aside from the noise.
Here's the first five threads that popped up on google:
http://www.ft86club.com/forums/showthread.php?t=40851
http://www.ft86club.com/forums/showthread.php?t=74154
http://www.ft86club.com/forums/showthread.php?t=46229
http://www.ft86club.com/forums/showthread.php?t=43890
http://www.ft86club.com/forums/showthread.php?t=12429
ineedyourdiddly
Old 10-09-2015, 03:33 PM   #7
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Since yours is "whiteout" and not "halo", it must be '13 or '14. It hasn't been making this noise for more than a year until recently. Happens only when it's cold and only when it's in neutral. When the clutch is depressed, the noise goes away.
I think this is new. None of the threads strat61caster linked to matches OP's problem.
Sigh-on-Rice is offline   Reply With Quote
Old 10-09-2015, 03:41 PM   #8
shellslinger
Thanks for the links but it doesn't describe the problems I'm having. I think I may just take it to the dealer tomorrow morning.
Old 10-09-2015, 03:43 PM   #9
strat61caster
Well, feel free to browse the ~1,500 results in the meantime, good luck.
https://www.google.com/?gws_rd=ssl#q...w.ft86club.com
ineedyourdiddly
Old 10-09-2015, 04:20 PM   #10
Sigh-on-Rice
Maybe same noise as this?
Old 10-09-2015, 04:50 PM   #11
shellslinger
Woah that is exactly what I'm experiencing.
Old 10-10-2015, 11:14 PM   #12
86Tony
Drives: 2015 AOZORA EDITION
Did this happen after you change to gear 300, mines made that noise when i did, then i went to get a new tranny since it had a 3rd to 4th gear grind, after tranny replace all was good. But it was for sure clutch related im.just gonna save up for a clutch kit
86Tony is offline   Reply With Quote
Old 10-10-2015, 11:51 PM   #13
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
It the vibrations passing though the flywheel. When your engine is in cold start it is creating more vibrations which pass though to the flywheel and clutch. These vibrations cause a chatter noise.
The noise will become more obvious with stiffer bushings as they don't dampen/asorb the engines vibrations as much. Anything that also removes mass will also increase the chatter (such as a lightweight crank pulley) or more so a lightweight flywheel.
It isn't unheard of for the OEM parts to chatter, if you feel excessive chatter is noticed it could be caused by worn parts (such as hot/spots, clutch glazing) or incorrect assembed/resurfaced parts(unlikely.) This is more common in aftermarket applications and not the original OEM equipment.
Old 10-11-2015, 12:00 AM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
There's nothing wrong. It's not the clutch. High compression engine, pretty light flywheel, and low idle wakes up the backlash in the gearbox. The gears are just rattling in neutral.
There's zero sound deadening in the tunnel so it's pretty audible.
Because racecar.
Exhaust rattle on cold start? Laurie Scion FR-S / Toyota 86 GT86 General Forum 8 12-04-2020 07:15 PM
Cold start rattle after header,op,fp installed by a newb aristo Engine, Exhaust, Transmission 5 10-28-2014 07:28 AM
Rattle sound on cold start Frs32907 Issues | Warranty | Recalls / TSB 0 07-12-2014 10:36 AM
rattle sound cold start marky Issues | Warranty | Recalls / TSB 1 03-24-2014 06:16 PM
Exhaust vibration/rattle at cold start? Foobar Engine, Exhaust, Transmission 7 04-16-2013 05:15 PM
