Drives: 2016 Toyota FRS
HID issue (solved, defective bulb)
***SOLVED!***
I have Innovited 55w AC HID conversion kit with relay harness. Relay is tested and functioning properly. Ground and battery connections were checked and good. Car is 2016 with less than 5000 miles. Battery and alternator are good. Innovited has given me beyond top notch response times and customer service. Every part has been replaced by them with everything arriving next day and well packaged/in good condition. I am not questioning the quality of their product. I am lost why the car is doing this. The issue: Both headlights turn on and warm up fine After some time the left side (driver's side) turns off If I turn the lights off and back on it will come on again (And repeat process) Video I made demonstrating the issue: Please help, this is embarrassing and unsafe Thank you!! Last edited by DustinDHP; 10-09-2015 at 01:50 AM. Reason: Problem solved |
Drives: 2016 Halo FRS
Hmm strange. My guess would have to be the ballast. My ballast have their own ground as well as the ground for the harness. So in all my HID kit has 3 grounds. 1 main one and each ballast has there own. But I'm following because I'm curious to know as well lol. Btw my HID kit is from diode dynamics and has been good to me so far.
probably a bad ballast or bulb. it's definitely not your car causing the problem, especially if you're tapping the ballast power directly from the battery. did you already swap with your replacement? check your grounds and double check your connections. then after that, it is time to trouble shoot. swap your left and right ballasts and see if it's the same side that goes out. if it is, then it is your bulb. if it changes sides, then it's the ballast
Trust86
Diode dynamics are really great, my LEDs are from them. Other people run these without issue. They don't have an extra ground like yours, so I tried mounting the ballasts to the chassis as I'm not trying to open these up and do some custom wiring. It didn't change anything, I didn't expect it to. But it was worth a shot. I definitely appreciate your suggestion! The ballast was ruled out as this only happens on the left side with all the ballasts Innovited has sent me, with and without using the relay harness Is your Diode Dynamics kit AC or DC? Are you running a relay harness? And are you using a resistor? |
Ryoma
I don't think it's the car either. I've lost count of how many times I've checked and reinstalled everything. However I just realized I haven't tested the bulbs. I'm about to swap the bulbs now. Could it be a bad bulb? |
Problem solved!! It's a defective bulb! Should get a new one from Innovited tomorrow
Thank you for your help guys!! Last edited by DustinDHP; 10-09-2015 at 01:59 AM. |
| A/C Issue? | FUN BRZ | Issues | Warranty | Recalls / TSB | 5 | 02-08-2014 02:34 PM |
| BRZ Nav MP3 issue | TheRipler | Electronics | Audio | NAV | Infotainment | 5 | 09-06-2013 02:21 PM |
| TCS Issue | subaruatheart | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 04-26-2013 01:28 PM |
| Anyone has the same issue like me? | ShowTime_DW | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 04-16-2013 10:23 PM |
| Anyone having this issue? | zoomzoomers | BRZ First-Gen (2012+) — General Topics | 11 | 08-09-2012 11:19 PM |
