Drives: Grey FR-S
9 Second 86 Build
Base Mods
FBM Walbro 485 Fuel Pump $330.00 Not Purchased http://fullblownmotorsports.com/full...-fuel-pump-kit Crawford Street Clutch $950.00 Not Purchased http://www.ft86speedfactory.com/craw...l#.VfsRliko7qA Private Label MFG Header $550.00 Not Purchased https://www.privatelabelmfg.com/mobi...SF-FA20-HEADER Ft86 Speed Factory Over/Front Pipe $550.00 Not Purchased https://jdlautodesign.net/shop/ft86-3-over-frontpipe/ Greddy Evo3 Catback Exhaust Installed Cost $2,380.00 Engine GSC Power Division Valve Springs $375.00 Not Purchased http://www.autohance.com/gsc-power-d...pYjhoCjP3w_wcB GSC Power Division Intake Valves $136.00 Not Purchased http://www.power-division.com/produc...cat=414&page=1 GSC Power Division Exhaust Valves $224.00 Not Purchased http://www.power-division.com/produc...cat=414&page=1 GSC Power Division Valve Guides $92.00 Not Purchased http://www.power-division.com/home.php?cat=415 Main Bearings $205.00 Not Purchased http://www.frsmod.com/products/fa20-...rs-for-frs-brz Rod Bearings $155.00 Not Purchased http://www.frsmod.com/products/fa20-...gs-for-frs-brz Engine Gasket kit $300.00 Not Purchased http://www.frsmod.com/products/fa20-...te-for-frs-brz Head Gasket $300.00 Not Purchased http://www.frsmod.com/products/dynos...t-frs-brz-fa20 Dynost Case Studds $350.00 Not Purchased http://www.frsmod.com/products/dynos...r-s-subaru-brz APR Head Studds $200.00 Not Purchased http://autoplicity.com/7586956-arp-2...irShoCI5jw_wcB Cost $2,337.00 Option 1 High Comp. Engine JE Pistons 13.5:1 $520.00 Not Purchased http://www.frsmod.com/products/je-pi...r-frs-brz-fa20 Carrillo Rods $1,500.00 Not Purchased http://www.frsmod.com/products/carri...ubaru-brz-fa20 Cost $4,357.00 Option 2 Stroker Engine HKS Stroker Kit $2,167.00 Not Purchased http://www.carid.com/hks/hks-stroker...eeqhoCCXbw_wcB HKS Camshafts $1,602.00 Not Purchased https://www.vividracing.com/catalog/...ZIiRoCY7jw_wcB Cost $6,106.00 Forced Induction Sprintex 335 Supercharger $5,709.00 Not Purchased http://www.moto-east.com/store/ft86/...c-335-kit.html NX Plate Kit $720.00 Installed MSD RPM Window Switch $129.00 Installed 5.7 Larger TB 22030-0S010 $200.00 Purchased Replace When Necessary DSS Rear Axles $900.00 Not Purchased http://www.moto-east.com/store/ft86/...-86-hd-pl.html DSS Aluminum Drive Shaft $405.00 Not Purchased http://www.moto-east.com/store/ft86/...-brz-alds.html Final Drive 4.44 or 4.67 $750.00 Not Purchased http://www.ft86speedfactory.com/driv...nufacturer=789 Megan Racing Engine Mount $195.00 Not Purchased https://www.ft86speedfactory.com/meg...Q#.Vei-a6Ao7qA Megan Racing Transmission Mount $66.00 Not Purchased https://www.ft86speedfactory.com/meg...Q#.Vei-x6Ao7qA Megan Racing Diff Brace $105.00 Not Purchased http://www.ft86speedfactory.com/mega...l#.Vei_PqAo7qA Megan Racing Diff Mount $130.00 Not Purchased http://www.ft86speedfactory.com/mega...l#.Vei_uKAo7qA $2,551.00 This is my parts list for my build. If any of you fellow 86 owners have any better part ideas I would love to hear your opinions. My parts list may change depending on what the community has to say about quality and reliability of the parts I havr all ready posted. My end goal is 9 seconds or under, but my real goal is to have the fastest 86 in the states with the fa20 engine still in it. |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Good luck ? I think your gona need like 8:1 and 30+ psi to do that?
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Why not go turbo? Im going for 9s or 8s as well. Going to keep it a banger car for a while but eventually ill go full retard and throw in a turbo400 or built 4l80 and 4 link 9" rear end.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
I'd say 45psi but 30 might do it. I'd also run at least a 70mm turbo, and you might want to look into a new trans...
Fierbuz did 9.96 on 550 hp and time attack suspension with a sequential. Lower compression just compensates for bad fuel. If you got e85 or q16 you dont need to lower compression much.
Not Bаnned Anymore
Yeah and maybe a whole new rear end?
If i decide to do a full on drag car im throwing in a full on solid rear end
Me and my buddies are going to make mine run 6's.
My list consists of the following: "mad engine mods" (not yet purchased) "sick ass snail" (not yet purchased) "Chinese header" (not yet purchased) "stock injectors" (Installed!) "stock trans" (installed!) "stock oil cooler" (installed!)
Killed Scion
Drives: 2013 FR-S Whiteout
I came into this thread hoping the car was already built.......
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque Last edited by MisterSheep; 10-05-2015 at 10:43 AM. |
#10 |
If you preload and slip the clutch you dont need a whole new rear end. If u dump and go youll break shit.
#11 |
Drives: Grey FR-S
I probably going to get a new trans and most likely a fbm rear end, but for now I just have spares lying around for when one gets destroyed so I can still drive the car. Anyone know a good aftermarket trans that fits the 86s. I saw a video of one but I cant remember what it was.
#12 |
Get a dogbox with an ignition cut on your shift lever so you can shift at WOT without using the clutch
#13 |
Drives: Grey FR-S
#14 |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| [B is for Build] BRZ resurrection build | im_topher | Member's Car Journals | 49 | 03-05-2018 09:41 AM |
| Superpenguin's "Not Another Build Thread!" Build Thread | superpenguin | Member's Car Journals | 7 | 06-17-2015 04:00 PM |
| No build date on passenger side sticker, how to determine build date? | BBYZILA | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 01-20-2015 10:14 PM |
| My BRZ build | brztj | Mid-Atlantic | 3 | 09-08-2012 05:52 PM |
