Old 10-02-2015, 05:54 PM   #1
dallenj
Drives: Grey FR-S
9 Second 86 Build
Base Mods
FBM Walbro 485 Fuel Pump $330.00 Not Purchased http://fullblownmotorsports.com/full...-fuel-pump-kit
Crawford Street Clutch $950.00 Not Purchased http://www.ft86speedfactory.com/craw...l#.VfsRliko7qA
Private Label MFG Header $550.00 Not Purchased https://www.privatelabelmfg.com/mobi...SF-FA20-HEADER
Ft86 Speed Factory Over/Front Pipe $550.00 Not Purchased https://jdlautodesign.net/shop/ft86-3-over-frontpipe/
Greddy Evo3 Catback Exhaust Installed
Cost $2,380.00
Engine
GSC Power Division Valve Springs $375.00 Not Purchased http://www.autohance.com/gsc-power-d...pYjhoCjP3w_wcB
GSC Power Division Intake Valves $136.00 Not Purchased http://www.power-division.com/produc...cat=414&page=1
GSC Power Division Exhaust Valves $224.00 Not Purchased http://www.power-division.com/produc...cat=414&page=1
GSC Power Division Valve Guides $92.00 Not Purchased http://www.power-division.com/home.php?cat=415
Main Bearings $205.00 Not Purchased http://www.frsmod.com/products/fa20-...rs-for-frs-brz
Rod Bearings $155.00 Not Purchased http://www.frsmod.com/products/fa20-...gs-for-frs-brz
Engine Gasket kit $300.00 Not Purchased http://www.frsmod.com/products/fa20-...te-for-frs-brz
Head Gasket $300.00 Not Purchased http://www.frsmod.com/products/dynos...t-frs-brz-fa20
Dynost Case Studds $350.00 Not Purchased http://www.frsmod.com/products/dynos...r-s-subaru-brz
APR Head Studds $200.00 Not Purchased http://autoplicity.com/7586956-arp-2...irShoCI5jw_wcB
Cost $2,337.00
Option 1 High Comp. Engine
JE Pistons 13.5:1 $520.00 Not Purchased http://www.frsmod.com/products/je-pi...r-frs-brz-fa20
Carrillo Rods $1,500.00 Not Purchased http://www.frsmod.com/products/carri...ubaru-brz-fa20
Cost $4,357.00
Option 2 Stroker Engine
HKS Stroker Kit $2,167.00 Not Purchased http://www.carid.com/hks/hks-stroker...eeqhoCCXbw_wcB
HKS Camshafts $1,602.00 Not Purchased https://www.vividracing.com/catalog/...ZIiRoCY7jw_wcB
Cost $6,106.00
Forced Induction
Sprintex 335 Supercharger $5,709.00 Not Purchased http://www.moto-east.com/store/ft86/...c-335-kit.html
NX Plate Kit $720.00 Installed
MSD RPM Window Switch $129.00 Installed
5.7 Larger TB 22030-0S010 $200.00 Purchased
Replace When Necessary
DSS Rear Axles $900.00 Not Purchased http://www.moto-east.com/store/ft86/...-86-hd-pl.html
DSS Aluminum Drive Shaft $405.00 Not Purchased http://www.moto-east.com/store/ft86/...-brz-alds.html
Final Drive 4.44 or 4.67 $750.00 Not Purchased http://www.ft86speedfactory.com/driv...nufacturer=789
Megan Racing Engine Mount $195.00 Not Purchased https://www.ft86speedfactory.com/meg...Q#.Vei-a6Ao7qA
Megan Racing Transmission Mount $66.00 Not Purchased https://www.ft86speedfactory.com/meg...Q#.Vei-x6Ao7qA
Megan Racing Diff Brace $105.00 Not Purchased http://www.ft86speedfactory.com/mega...l#.Vei_PqAo7qA
Megan Racing Diff Mount $130.00 Not Purchased http://www.ft86speedfactory.com/mega...l#.Vei_uKAo7qA
$2,551.00
This is my parts list for my build. If any of you fellow 86 owners have any better part ideas I would love to hear your opinions. My parts list may change depending on what the community has to say about quality and reliability of the parts I havr all ready posted. My end goal is 9 seconds or under, but my real goal is to have the fastest 86 in the states with the fa20 engine still in it.
dallenj is offline   Reply With Quote
Old 10-02-2015, 05:57 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Good luck ? I think your gona need like 8:1 and 30+ psi to do that?
Old 10-02-2015, 05:58 PM   #3
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Why not go turbo? Im going for 9s or 8s as well. Going to keep it a banger car for a while but eventually ill go full retard and throw in a turbo400 or built 4l80 and 4 link 9" rear end.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 10-02-2015, 05:59 PM   #4
raven1231
I'd say 45psi but 30 might do it. I'd also run at least a 70mm turbo, and you might want to look into a new trans...
Old 10-02-2015, 05:59 PM   #5
#maverick#
#maverick#'s Avatar
Fierbuz did 9.96 on 550 hp and time attack suspension with a sequential. Lower compression just compensates for bad fuel. If you got e85 or q16 you dont need to lower compression much.
Old 10-02-2015, 06:00 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah and maybe a whole new rear end?
Old 10-02-2015, 06:02 PM   #7
#maverick#
#maverick#'s Avatar
If i decide to do a full on drag car im throwing in a full on solid rear end
Old 10-02-2015, 06:02 PM   #8
raven1231
Me and my buddies are going to make mine run 6's.
My list consists of the following:
"mad engine mods" (not yet purchased)
"sick ass snail" (not yet purchased)
"Chinese header" (not yet purchased)
"stock injectors" (Installed!)
"stock trans" (installed!)
"stock oil cooler" (installed!)
Old 10-02-2015, 06:03 PM   #9
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I came into this thread hoping the car was already built.......
Instagram: trevor.parque
Old 10-02-2015, 06:03 PM   #10
#maverick#
#maverick#'s Avatar
If you preload and slip the clutch you dont need a whole new rear end. If u dump and go youll break shit.
Old 10-02-2015, 06:12 PM   #11
dallenj
Drives: Grey FR-S
I probably going to get a new trans and most likely a fbm rear end, but for now I just have spares lying around for when one gets destroyed so I can still drive the car. Anyone know a good aftermarket trans that fits the 86s. I saw a video of one but I cant remember what it was.
Old 10-02-2015, 06:27 PM   #12
#maverick#
#maverick#'s Avatar
Get a dogbox with an ignition cut on your shift lever so you can shift at WOT without using the clutch
Old 10-02-2015, 06:31 PM   #13
dallenj
Drives: Grey FR-S
What is a dogbox
Old 10-02-2015, 06:33 PM   #14
#maverick#
#maverick#'s Avatar
Originally Posted by dallenj View Post
What is a dogbox
Straight cut gears. No synchros
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
[B is for Build] BRZ resurrection build im_topher Member's Car Journals 49 03-05-2018 09:41 AM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 04:00 PM
No build date on passenger side sticker, how to determine build date? BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 5 01-20-2015 10:14 PM
My BRZ build brztj Mid-Atlantic 3 09-08-2012 05:52 PM
