Old 10-02-2015, 05:35 PM   #1
HachiRo
Drives: 2013 White-Out FRS
LCAs needed for SuperDown/Sportlines?
So I'm planning to lower my car on either Eibach Sportlines or RSR Superdowns. The drops are over an inch and from what I've read, there will be quite some camber in the rear. I'm trying to get 0 toe and as little camber as possible to prolong the life of the tires. I understand that even with a bit of camber, the tire life will only decrease by a small amount.
So here's the main question..
Would LCAs be necessary? Could I just get an alignment with stock parts and get 0 toe and less camber?
I'm just wondering if 400-500$ LCAs would outweigh the cost of slightly decreased tire life.
Anyone running Superdowns or Sportlines for daily driving, please chime in with your set-up and tips/recommendations!
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 10-02-2015, 06:02 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
You can get a little adjustment with 12mm eccentric bolts in the back (I think that's right, anyway,) but if you want ready adjustment, LCA's are worth it.
That said, proper camber adds so much to the driving experience, I have to say you should take what you get and focus on evening it only... And get bolts or camber plates to add as much as you can on the front.
Old 10-02-2015, 07:04 PM   #3
HachiRo
Well, tbh, I'm going with 18 x 10.5 in the back wheels LOL, so I'm not sure if even -2.x camber would be a huge difference. Front would be 18x9.5 and I don't mind camber in front, just the rear.
Only reason I ask is because I came across a set of LCAs and I can sell them for a 400$ turnaround, but not sure if that 400$ is a good sell or it's better to keep them and use.
Without any aftermarket bolts, would the camber be a noticeable difference with wheels that wide?
Can toe be adjusted without LCAs?
Old 10-02-2015, 07:11 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
Toe can be assured stock.
With that wheel setup you are going to understeer anyway, but may have fitment issues without negative camber in the back, and may need to add over what the springs will add to avoid rubbing. Wheels won't change camber though.
Staggered wheels hurts handling. Add that to lots of rear camber, little front, its going to... Suck.
The information to help you is here for the finding, and I'm a little unsure you're heading towards a setup that will work (as in, fit without rubbing.)
The Following User Says Thank You to cjd For This Useful Post:
JazzleSAURUS (10-12-2015)
Old 10-02-2015, 07:12 PM   #5
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
im using SPC rear control arms. highly recommend them to fix your rear camber. i was -2.2 on the natural drop of my sportline springs, i'm running -1.0 in the rear now
malubawla is offline   Reply With Quote
Old 10-02-2015, 07:16 PM   #6
HachiRo
I'll be honest, I'm going widebody haha. Yeah, handling will suck and I've kinda faced that and pitted it towards the fact that I use my car for daily driving with the only spirited driving I do on late nights on my way home which is a 10 minute drive, haha. Other than that, the car is parked quite often. Please don't flame me
Definitely going to kill the "fun" factor of the car for the looks factor :\
Old 10-02-2015, 07:16 PM   #7
Calum
That Guy
Drives: 2013 asphalt FRS MT
There is adjustment for toe with the stock parts.
If you're going to run wheels that wide you'll likely need the coilovers, and I'd bet your camber setting will be solely dependant on making those cartoonishly big wheels not rub. The eccentric bolts get you about half a degree plus or minus. You'll likely need more range than that, but I'm not sure and nobody else can be sure until you get the wheels, set your ride height and see. Check the meaty tire thread and see what other like minded people are doing to make it work and how much they had to adjust.
Old 10-02-2015, 07:17 PM   #8
HachiRo
Originally Posted by malubawla View Post
im using SPC rear control arms. highly recommend them to fix your rear camber. i was -22.2 on the natural drop of my sportline springs, i'm running -1.0 in the rear now
Was the -22.2 camber visually noticeable with your wheels or was it mainly something that you noticed on tire life?
Old 10-02-2015, 07:25 PM   #9
HachiRo
If lowering on springs, there camber might be a different degree on each side right?
Is there anyway to correct camber with stock parts to make it even at least? Not necessarily getting rid of it, but just making it even.
Let's say I lower and it's -20 and -15 or something.
Old 10-02-2015, 09:21 PM   #10
Calum
That Guy
There is no adjustment for camber in the stock setup.
As was mentioned, 12mm camber bolts can be installed in the rear lower control arm inner mounting point to get plus or minus ~half a degree. That should be enough to even things out.
Old 10-02-2015, 09:44 PM   #11
HachiRo
Can install be done by myself? I heard there's a bushing or something that's really hard to work around, or something lol I forgot.
Old 10-02-2015, 09:54 PM   #12
cjd
cjd's Avatar
Drives: 2017 BRZ
Don't try. Can it? Yes. But your questions here make me think its too much to bite off. I've done my own alignment before successfully, and that was it. Not happening again.
Being honest with your goals is good. I'm not into widebody or staggered superwide wheels, but people like that.
Do take the time to research. Offset and clearance and many things need attention. If you can afford all this stuff, consider RS-R's coilovers vs springs, for example. They'll give you a lot more space for those wheels/tires.
C
HachiRo (10-02-2015)
Old 10-02-2015, 11:47 PM   #13
HachiRo
C
Will do, definitely going to look into Coils and with this, I'll use/keep the LCAs I have. Just hope Stance V1 LCAs are good :P.
Thanks everyone!
Old 10-02-2015, 11:52 PM   #14
ryoma
ryoma's Avatar
btw, the -22.2 was most likely a typo. his camber is most likely -2.22. I have -1.5 already in the rear and I haven't done anything suspension-wise.
RSR Superdown owners HachiRo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-04-2015 06:44 PM
WTB RSR Superdown BokChoiTV Want-To-Buy Requests 5 03-25-2015 01:46 PM
WTB: RS*R Superdown and Whiteline or SPC camber bolts sissupr Want-To-Buy Requests 0 03-15-2015 05:14 PM
wtb NEW Sportlines or barely used sportlines VakaGT Want-To-Buy Requests 1 08-19-2014 08:02 PM
AP Rear LCAs JDLAutoDesign Brakes, Suspension, Chassis 2 04-17-2014 03:43 PM
