Old 07-15-2015, 05:51 PM   #1
Kodename47
Kodename47's Avatar
Drives: UK GT86
Transient Fueling ~ DI/PI
This is really more relevant go those who have changed port injectors, but I had a question/idea for those good with code.
ECUtek and Romraider show 2 transient fueling tables, they are both set the same. It would seem obvious that if you install larger port injectors that you would reduce the transient tables.... or would it? What happens when operating in DI only mode? Is this a further table that's not been located, one of the 2 tables already defined or is it not even relevant due to the instantaneous nature of direct injection?
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-16-2015, 11:25 PM   #2
ztan
Drives: Toyota 86
Tried to have a look, the overall fuelling code is actually quite complex and dependent on many, many byte value switches which have not been defined properly yet. Knowing which ones actually affect DI/PI/Combined/Idle/OL/limp home is going to take a long time to understand.
ztan is offline   Reply With Quote
The Following 2 Users Say Thank You to ztan For This Useful Post:
aagun (07-17-2015), Kodename47 (07-17-2015)
Old 07-17-2015, 06:27 AM   #3
aagun
Drives: 86
Injector Flow Scaling table could be help ?
aagun is offline   Reply With Quote
Fueling Issue Simisimi Issues | Warranty | Recalls / TSB 5 12-22-2014 05:17 PM
Rotrex vs Turbo (AVO) for Track use (transient response, IATs, heat management, etc) glamcem Forced Induction 56 08-25-2014 06:07 PM
Transient ignition and knock count brn12345 Software Tuning 19 06-10-2014 11:46 PM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
Re-fueling Timing and Amount Chad86 Scion FR-S / Toyota 86 GT86 General Forum 26 03-15-2014 02:03 PM
