Drives: 2014 Scion FR-S
Replacement Rear Tire
I was hearing a clicking noise in my car, turns out to be a nail dug into my rear tire. obviously the dealership wont cover it, and they're trying to charge me $211 to replace my one tire.
Is it just me or am I being ripped off? If so, do you guys have any info on where else I can get a cheap stock michelin tire from thanks.sincerely, sad broke boi. |
Drives: 2015 CWP BRZ Limited
You can probably get a barely used, full set on here for not a lot more than what the dealer is asking for the OEM tire.
That said, the price they're quoting is about right for a full replacement. I'm not sure if you actually need a full replacement, though. If the nail hasn't damaged the sidewall, you can usually patch or plug it, which is less than 50 bucks at basically any tire shop. |
#3 | |
I'll have it checked out then. Thank you! |
Drives: '16 BRZ
I would also take it to a tire repair shop especially if the damage is not in the sidewall.
| Wheel stud replacement | Dave-ROR | DIY (Do-It-Yourself) Guides | 267 | 01-21-2022 08:20 PM |
| Emblem Replacement for Steering Wheel | MisterSheep | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 07-30-2015 07:55 PM |
| Steering Wheel Replacement / Swap | CorranFox | Cosmetic Modification (Interior/Exterior/Lighting) | 22 | 07-24-2015 10:22 PM |
| Replacement Lug Stud/Wheel Hub | swift996 | Issues | Warranty | Recalls / TSB | 3 | 08-30-2013 01:58 PM |
| Rear Badge Piece Replacement? | Wesley | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 09-20-2012 06:38 PM |
