Drives: FRS RS 1.0
DIY camber adjustments?
if all i want to do is add some front camber to an otherwise stock car, is it feasible to install camber plates myself and adjust it at home? or am i going to impact toe/caster when i move the camber around?
#2 | |
That Guy
Drives: 2013 asphalt FRS MT
I'd suggest you look into camber bolts if money is an issue. They only take a minute to install for an alignment tech that already has the car on a lift so they typically won't charge extra. The cost of bolts and an alignment would be less than just buying the camber plates. Bolts also have the added bonus of not increasing NVH and they don't require as much maintenance. You can get the bolts from any number of places, including a Subaru dealership. |
| School me on camber adjustments... | tanner | CANADA | 34 | 01-14-2016 10:31 PM |
| Compression/Rebound Adjustments | amaciose | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 12-10-2014 05:51 AM |
| Cam timing adjustments without dyno | StormTrooper | Software Tuning | 17 | 02-19-2014 05:16 PM |
| Pedal adjustments | supramkivtt2jz | DIY (Do-It-Yourself) Guides | 3 | 03-31-2013 06:56 AM |
| Pedal Adjustments? | djliquidsteele | Engine, Exhaust, Transmission | 3 | 06-09-2012 11:43 AM |
