Old 12-09-2014, 04:12 PM   #1
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
Compression/Rebound Adjustments
I recently installed a set of KW V3's per the recommended "street use" settings by @Racecomp Engineering:
http://www.ft86club.com/forums/showp...96&postcount=4
After driving it around a bit, I could tell that they had a stiffer feel when hitting bumps in the road (as expected), but the car sort of had a bit of a "floaty" feel to it. I understand the process of adjusting the settings, but is there any good source for the theory behind which setting to adjust for certain situations, like when to adjust compression vs rebound, and in what direction to change the setting? Maybe I have to adjust a combination of both?
amaciose is offline   Reply With Quote
Old 12-09-2014, 05:14 PM   #2
totopo
Drives: 370z
http://www.penskeshocks.com/assets/A...e%20Manual.pdf (starting at page 16, though all of it is good background)
It's not as easy as one may think. Especially for the 99.9999% of us that are amateur drivers. How do you know what you like is what you are supposed to like? or what makes the car faster? or what makes the car more predictable?
http://farnorthracing.com/autocross_secrets6.html
totopo is offline   Reply With Quote
The Following User Says Thank You to totopo For This Useful Post:
amaciose (12-09-2014)
Old 12-09-2014, 06:19 PM   #3
amaciose
amaciose's Avatar
Thanks, I'll check these links out. I figured it wouldn't be a simple process, but I was just looking for some direction on where to start.
Old 12-09-2014, 08:58 PM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Keep notes. No point in making adjustments if you don't remember what settings you have already played with.
Old 12-10-2014, 05:15 AM   #5
Mikeez
Engineering Student
Drives: Scion FR-S 2015
From what I know, you need to know what you've previously set. If you're use KW's preset, go from there with incremental clicks every day and experience it. Note it down
Don't take people's opinion on here, they mislead.
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 12-10-2014, 05:38 AM   #6
Captain Snooze
Drives: Red Herring
Thanks for paraphrasing what I had posted above.
So we can disregard your post?
Old 12-10-2014, 05:43 AM   #7
Captain Snooze
Drives: Red Herring
Page 5 of this pdf gives some guidelines to 2 way damper adjustment.
Old 12-10-2014, 05:47 AM   #8
juliog
juliog's Avatar
Drives: 86
[ame="http://en.wikipedia.org/wiki/Liar_paradox"]Liar paradox - Wikipedia, the free encyclopedia[/ame]
juliog is offline   Reply With Quote
The Following User Says Thank You to juliog For This Useful Post:
Captain Snooze (12-10-2014)
Old 12-10-2014, 05:51 AM   #9
Captain Snooze
Drives: Red Herring
Yes!! That occcured to me too.
juliog (12-10-2014)
Tein SRC rebound and compression set up for track mtsui Tracking / Autocross / HPDE / Drifting 13 02-27-2014 09:36 PM
Cam timing adjustments without dyno StormTrooper Software Tuning 17 02-19-2014 05:16 PM
Pedal adjustments supramkivtt2jz DIY (Do-It-Yourself) Guides 3 03-31-2013 06:56 AM
Valve Train Adjustments @Art_Mighty Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-24-2012 10:10 PM
Pedal Adjustments? djliquidsteele Engine, Exhaust, Transmission 3 06-09-2012 11:43 AM
