Old 09-28-2015, 07:51 AM   #1
Wil
Wil's Avatar
Drives: Drives like a crab.
Safest way to install LED turn signals
Hello everyone,
I've been looking for a couple of weeks to swap the regular turning lights bulbs to LED.
I've browsed eBay and found a lot of offers on the subject.
-Some cheapos from China
-Some quality ones from the US
-Some that come with load resistors
-Tail as Turn style devices
There seems to be many many ways to install LED in a GT86 but I read not all of them are safe.
For example, adding load resistors (6ohm 50W) is risky since they can get really really hot and melt the rear lights or even set fire to the booth.
Not adding anything make the LED hyperblink.
Does adding a Flasher is recommended if you only install LED on the rear lights (or rear and front but not side markers ?).
Plus can you tell me if front turn signal bulbs are 7440 or 7443 on a GT86 ?
Owner's manual indicated WY21W for both.
So, to you, what is the safest way to install LED turning lights in a GT86 ?
Thank you.
Have a nice day.
Wil is offline   Reply With Quote
Old 09-28-2015, 12:33 PM   #2
stevesnj
stevesnj's Avatar
Hope this helps, I installed the bulbs around a month ago. You will need an LED electronic flasher.
http://www.ft86club.com/forums/showp...&postcount=129
Flasher
[ame="http://www.amazon.com/gp/product/B008C9YS0Y?psc=1&redirect=true&ref_=oh_aui_detailp age_o03_s00"]Amazon.com: 8-Pin 81980-50030 066500-4650 Electronic LED Flasher Assy Relay Fix For Lexus Scion or Toyota LED Turn Signal Light Bulbs: Automotive[/ame]
My 2016 Build thread
Old 09-28-2015, 12:39 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Just buy a new flasher for LED's. If you were local I would give you my extra one. I have be running LED's for over 2 years with 0 issues.
Old 09-28-2015, 03:03 PM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
The short answer is: All you need are the bulbs and the electronic flasher module listed on this page. I bought the XP80s, and I wouldn't recommend anything less as it will not be bright enough.
http://www.diodedynamics.com/store/l...pplication=210
Stang70Fastback is offline   Reply With Quote
Old 09-30-2015, 06:19 AM   #5
Wil
Wil's Avatar
Thank you all for your answers !
But should I use a flasher if I only put LED for the rear turn signals ?
Won't it affect the blinking speed of the halogen bulbs ?
Old 09-30-2015, 07:03 AM   #6
LED86
LED86's Avatar
Drives: Black 86 GTS
You will need an LED relay as soon as you change any of the indicator bulbs (front/rear/sides). Once an LED bulb is installed in any of the indicators the system thinks a bulb is blown and all will flash rapidly to make the driver aware a bulb is out. The LED relay will correct it back to normal.
The regular LED relays you see around do the job fine but have a delay on the first flash. Valenti relays don't have this and also have euro tap feature (tap stalk to make the indicators flash 3x for lane merging) and the tap turn guys in the USA have a similar relay with even more extra features.
LED86 is offline   Reply With Quote
Old 09-30-2015, 01:17 PM   #7
stevesnj
stevesnj's Avatar
In case you're looking for the front switchbacks I found the link. http://www.aliexpress.com/item/High-...862156145.html
If you're willing to wait a week or 2 they work amazing!
Old 09-30-2015, 04:51 PM   #8
Wil
Wil's Avatar
Thanks you for the awesome support!
I'm not that much into switchback but thank you for the proposition.
Is the Valenti flasher the only unit that avoids the one second delay ?
Because that's the kind of thing that could annoy me but paying 6 times the price of a regular flasher is something.
Old 10-09-2015, 08:36 PM   #9
johnbradshow
Drives: Audi
It is very hard to find the correct flasher module since there are too many different ones.
johnbradshow is offline   Reply With Quote
These beautiful turn signals ... matthui95 Cosmetic Modification (Interior/Exterior/Lighting) 24 12-28-2014 08:17 PM
WTB: Front turn signals (FR-S) sirsol66 Want-To-Buy Requests 2 12-16-2014 03:20 AM
DIY JWMotoring LED turn signals sirhc DIY (Do-It-Yourself) Guides 54 03-16-2013 03:22 PM
Custom turn signals? benlevy3 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-01-2012 03:23 PM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
