Old 09-26-2015, 08:58 PM   #1
radroach
Drives: car
New OEM clutch! Thoughts.
So I'm at ~56k miles and had some major worked put in on the car today, new spark plugs and a new OEM clutch! Done by a local tuner shop.
So my thoughts are, this is something I should have done a long time ago. 3 years on the original clutch. I've been having gears do a mini-grind almost every day for the last year, and maybe evidence that the clutch was lightly dragging because I'd hear faint scratching noises. During downshifts the throw out bearing would make a honking noise, or while going downhill in low gear I'd hear a slight grinding sound. And when I'd engage or disengage the clutch I'd hear a knocking sound. Apparently all of this is a symptom of a bad throw out bearing, and when we took out the bearing, it was clearly worn and making noises if you spun it by hand.
So new clutch, new motul gear 300 oil, and my thoughts. Well the first time I got in the car, I noticed that the clutch was WAAAY lighter than it was before. I asked the guy if he did anything, he said nope, it was just lubed up so much that there was no friction. The drive home though was amazing, down some insane switchbacks on TN mountain roads I'd never been on. The engine revved without the feeling of friction it had before, and downshifts were bang-on, I was rev matching speeds way easier, say where I normally rev matched 2nd at a maximum of 30mph before, now I think I rev matched it at ~38mph and had no problem.
The motul gear 300 makes the gearbox feel too light, vague, and I never liked that, but gear changes are super smooth and quick. Over time, I hope it settles out so there is a little more feeling in the clutch, but overall it's going to work out.
What should you get out of this: I think that if you have any of the above symptoms of a bad throw-out bearing, you should plan on getting it replaced as soon as you can. This is something I should have done at the first sign that my throw-out bearing was honking at me. Thanks.
Old 09-26-2015, 09:06 PM   #2
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
The motul gear 300 makes the gearbox feel vague, and I never liked that, but gear changes are super smooth. Over time, I hope it settles out so there is a little more feeling in the clutch, but overall it's going to work out.
I would also suggest to take out the spring behind the clutch. It helps with the clutch feel and makes it very easy to shift without feeling vague
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 10-13-2015, 06:17 PM   #3
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
How much did you spend on the OEM clutch and the labor if you don't mind me asking?
mikeTee is offline   Reply With Quote
Old 10-13-2015, 09:39 PM   #4
radroach
Drives: car
A new clutch was about $250 at the time, bought from here: http://www.ft86speedfactory.com/exed...l#.Vh2x6ytOLOA
I had spark plugs and clutch job done at the same time, and that cost me probably $950. I'd say half of that went to the clutch job + replacing the transmission fluid.
Old 10-14-2015, 03:48 AM   #5
humfrz
So I'm at ~56k miles and had some major worked put in on the car today, new spark plugs and a new OEM clutch!............ .
Too bad your car's clutch went bad after only 56,000 miles......
What are your thoughts on why you think the clutch went bad ..... ??
humfrz
Old 10-14-2015, 05:07 PM   #6
radroach
Drives: car
humfrz
It was the throw out bearing that had gone bad. It started being noisy, and at times it felt like the clutch was dragging or not disengaging all the way.
I will admit I was hard on it at times and so not surprised that that part wore out quickly.
Thoughts about rebuilding stock clutch. (or, conversation about friction materials) qtwre Engine, Exhaust, Transmission 0 07-09-2014 12:56 PM
Clutch Master's FX300 Thoughts Opinions evilconcarne999 Engine, Exhaust, Transmission 16 07-03-2013 01:21 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
