Old 09-26-2015, 06:05 PM   #1
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
Shiv dyno day 2 in lewisville, OFT users custom dyno tunes
closed
malubawla is offline   Reply With Quote
Old 09-30-2015, 03:26 PM   #2
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
1. Malubawla (turbo)
2.
3.
4.
5.
6.
Old 10-01-2015, 11:53 PM   #3
Griever423
Drives: 2020 BRZ PP
I'll be checking in later with hopefully a deposit. I'm running Grimmspeed intake, OFT and OFH. Would an aftermarket overpipe/frontpipe combo net me any significant gains? A little more power would be welcome.
I want to keep the volume down as much as possible so catback will stay stock most likely.
Griever423 is offline   Reply With Quote
Old 10-02-2015, 10:56 AM   #4
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Normally the header is what nets you the most gains, but I still recommend an aftermarket OP/FP combo. If you're going to dyno a NA application and get a custom tune, you might as well go all out and have full bolt ons prior to getting tuned. That way you see the best results. Also, a good catback alternative is the TRD exhaust if you can afford it. Not super loud but gives the car a very unique and nice exhaust note.
MokSpeed is offline   Reply With Quote
Old 10-02-2015, 11:32 AM   #5
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
I would also recommend a switch to E85 if you have it near you. The gains alone with E85 are worth it.
Shneegle is offline   Reply With Quote
The Following User Says Thank You to Shneegle For This Useful Post:
JonAvalon (10-02-2015)
Old 10-02-2015, 12:01 PM   #6
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Agree with @Shneegle, if you're going to get tuned by Shiv you might as well go all out with E85 as well.
I might be interested in the January session especially if I add other N/A mods. I've been tweaking my tunes from the guides in the tuning section but eh it would be better if Shiv dialed it in properly. I'm trying to get @denellum to join too since it looks like he will have the SBD kit installed by then.
JonAvalon is offline   Reply With Quote
Old 10-02-2015, 12:59 PM   #7
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
Get an aftermarket frontpipe. If you look at our dyno day, i made the most power and im running just a tsudo header with full exhaust. i would say that the frontpipe definitely helped.
Old 10-02-2015, 09:37 PM   #8
Griever423
Drives: 2020 BRZ PP
There is no E85 readily available to me otherwise you best believe I'd be running it.
Old 10-04-2015, 07:50 AM   #9
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
I usually see E85 only at Kroger Gas Stations. I always was curious to try it out myself
Old 10-04-2015, 09:01 AM   #10
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
so can i put you on the list?
Old 10-04-2015, 10:57 AM   #11
JonAvalon
SCBYD0
JonAvalon's Avatar
What part of Fort Worth are you in? I can point out where I normally go but they might be too far if you're in the southern part.
Old 10-07-2015, 12:09 PM   #12
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
any OFT users interested in a custom dyno tune?
Old 10-19-2015, 03:37 PM   #13
Griever423
Drives: 2020 BRZ PP
I live in west fort worth. Near River Oaks
Old 11-02-2015, 12:10 AM   #14
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
bump any interest?
The Following User Says Thank You to malubawla For This Useful Post:
WillRacer1jz (11-02-2015)
DFW Shiv OFT Dyno Tune (9/12/15 Session 1 Completed) malubawla Southwest 80 09-29-2015 10:40 PM
- 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune aaronsadventures Member's Car Journals 6 12-04-2014 02:01 AM
Feeler: Dyno Tuning Session via Jamesm @ HRI tuning sw20kosh Northern California 27 11-28-2014 07:53 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
Dyno tune near CNJ? Craig NY / NJ / CT / PA 2 01-31-2013 06:57 AM
