Old 09-26-2015, 06:05 PM   #1
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
Shiv dyno day 2 in lewisville, OFT users custom dyno tunes
closed
malubawla is offline   Reply With Quote
Old 09-30-2015, 03:26 PM   #2
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
1. Malubawla (turbo)
2.
3.
4.
5.
6.
Old 10-01-2015, 11:53 PM   #3
Griever423
Drives: 2020 BRZ PP
I'll be checking in later with hopefully a deposit. I'm running Grimmspeed intake, OFT and OFH. Would an aftermarket overpipe/frontpipe combo net me any significant gains? A little more power would be welcome.
I want to keep the volume down as much as possible so catback will stay stock most likely.
Griever423 is offline   Reply With Quote
Old 10-02-2015, 10:56 AM   #4
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Normally the header is what nets you the most gains, but I still recommend an aftermarket OP/FP combo. If you're going to dyno a NA application and get a custom tune, you might as well go all out and have full bolt ons prior to getting tuned. That way you see the best results. Also, a good catback alternative is the TRD exhaust if you can afford it. Not super loud but gives the car a very unique and nice exhaust note.
MokSpeed is offline   Reply With Quote
Old 10-02-2015, 11:32 AM   #5
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
I would also recommend a switch to E85 if you have it near you. The gains alone with E85 are worth it.
Shneegle is offline   Reply With Quote
Old 10-02-2015, 12:01 PM   #6
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Agree with @Shneegle, if you're going to get tuned by Shiv you might as well go all out with E85 as well.
I might be interested in the January session especially if I add other N/A mods. I've been tweaking my tunes from the guides in the tuning section but eh it would be better if Shiv dialed it in properly. I'm trying to get @denellum to join too since it looks like he will have the SBD kit installed by then.
JonAvalon is offline   Reply With Quote
Old 10-02-2015, 12:59 PM   #7
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
Get an aftermarket frontpipe. If you look at our dyno day, i made the most power and im running just a tsudo header with full exhaust. i would say that the frontpipe definitely helped.
Old 10-02-2015, 09:37 PM   #8
Griever423
Drives: 2020 BRZ PP
There is no E85 readily available to me otherwise you best believe I'd be running it.
Old 10-04-2015, 07:50 AM   #9
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
I usually see E85 only at Kroger Gas Stations. I always was curious to try it out myself
Old 10-04-2015, 09:01 AM   #10
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
so can i put you on the list?
Old 10-04-2015, 10:57 AM   #11
JonAvalon
SCBYD0
JonAvalon's Avatar
What part of Fort Worth are you in? I can point out where I normally go but they might be too far if you're in the southern part.
Old 10-07-2015, 12:09 PM   #12
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
any OFT users interested in a custom dyno tune?
Old 10-19-2015, 03:37 PM   #13
Griever423
Drives: 2020 BRZ PP
I live in west fort worth. Near River Oaks
Old 11-02-2015, 12:10 AM   #14
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
bump any interest?
DFW Shiv OFT Dyno Tune (9/12/15 Session 1 Completed) malubawla Southwest 80 09-29-2015 10:40 PM
- 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune aaronsadventures Member's Car Journals 6 12-04-2014 02:01 AM
Feeler: Dyno Tuning Session via Jamesm @ HRI tuning sw20kosh Northern California 27 11-28-2014 07:53 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
Dyno tune near CNJ? Craig NY / NJ / CT / PA 2 01-31-2013 06:57 AM
