Old 09-23-2015, 08:59 AM   #1
Papi
Drives: Crystal White Silica BRZ Limited
Dome LED mod?
Does anyone know if it possible to incorporate Acree mod for a dual light
http://www.ft86club.com/forums/showp...70&postcount=7
and link it to the auto light feature. I want the car to use the auto light module to power the dome and accent red led when it's dark. I need to add a switch that you can push to get the white light if you need it. Can this be done?
Has anyone been able to get ahold of Acree?
Papi is offline   Reply With Quote
Old 09-25-2015, 01:13 PM   #2
Poodles
Drives: 2015 Series.Blue
IIRC he's on HIDplanet. Anything is possible with enough wiring knowhow...
Old 09-25-2015, 01:41 PM   #3
Chimera
Drives: FRS
depending on how clean you wanted it, you could wire in a board or 2 of colored accent LEDs and have them wired to the dome circuit, then put a board of white up there, and wire it to an independent circuit off the battery with a fuse, switch, and relay.
Old 09-25-2015, 02:32 PM   #4
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I made my own as well. I never got enough interest to make it worthwhile.
Old 09-26-2015, 04:08 PM   #5
Papi
Bored is me
I was trying to see if you had a write up on your light setup
Old 09-26-2015, 05:41 PM   #6
boredom.is.me
Custom User Title
My white operates normally. I keep it in the off position though.
The red comes on whenever the doors open.
Write up? Not for this one. Sorry, but I don't intend to either.
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 09:39 PM
RGB dome lbroskee Cosmetic Modification (Interior/Exterior/Lighting) 0 02-25-2014 11:34 AM
FS: Dome LED Firestorm_86 Interior Parts (Incl. Lighting) 0 10-21-2013 10:39 AM
Cluster dome <---you need this! sav AFRICA 29 04-26-2013 04:38 AM
