Old 09-22-2015, 03:09 PM   #1
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I want this in my life (brake duct)
http://mynetz.jp/bluearea/item_page.aspx?id=001704
It's actually an option on OEM Japan toyota 86 racing grade. (I have catalog)
Now you can buy it just as a part separately O.o
Ya.......... 200 buck
Picture belongs to Calen in Miyagi prefecture on minkara
Now does it work?
For testing purpose it's only installed on one side.
& Yes you can't see it unless car is jacked up or you are looking @ it from even ground level.
Car as it sits still @ 22 celcius (71.6f)
After spirited driving
The side with air duct is 45 celcius (113f)
The side without is 89 celcius (192f)
After pushing it hard, the side with air duct is sitting @ 88 celcius (190f)
The side without @ 111 celcius (232f)
figure it's a "cool" part to share
The Following 20 Users Say Thank You to chaoskaze For This Useful Post:
8R6 (09-22-2015), akyp (09-22-2015), BWilky (12-23-2015), Createddeleted (09-23-2015), CxG (10-29-2015), Decay107 (09-22-2015), flippy (09-25-2015), GotBRZ1691 (11-01-2015), GT86_PRAGUE (09-29-2015), Guff (11-11-2015), JustBoostin (07-17-2016), Kami Speed (09-22-2015), Metabrz (11-29-2015), MisterSheep (09-22-2015), mokinbird87 (11-09-2015), nikitopo (08-15-2016), radroach (11-14-2015), SkAsphalt (09-24-2015), soulreapersteve (11-07-2015), yo joshman (09-29-2015)
Old 09-22-2015, 03:12 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Instagram: trevor.parque
Old 09-22-2015, 04:29 PM   #3
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
Wow, what a huge difference just that one piece makes! Great post man
Kami Speed is offline   Reply With Quote
Old 09-22-2015, 05:44 PM   #4
ryoma
ryoma's Avatar
I wonder if there is an easy way to make it yourself for a few bucks. it looks like a simple piece
Old 09-22-2015, 08:34 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
I guess that this have pros of being simpler to fit (as no need to route/pass air tubes/ducts like for APR or TF ducts), but cons - easier to scrape/damage/stuff with snow due being closer to ground.
Old 09-22-2015, 08:43 PM   #6
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Cons also might be not as effective since it's not ducted as direct
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 09-22-2015, 08:48 PM   #7
philooo
Drives: 13' Scion FRS Track car
looks like a nice simple and effective mods for non lowered cars.
If you do lower the car, I am afraid the piece may get damage very quickly.
you would probable better off installing the porsche gt3 brake ducts. they cost $30 on eBay and can be added to the control arm pretty well.
Again this is more for non lowered cars.
philooo is offline   Reply With Quote
Old 09-22-2015, 09:39 PM   #8
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Wink
It's good for minimal drop. The owner of this car is on HKS hipermax GT with 1.18 inch(3cm) up front, 1.37(3.5cm) in the rear.
Fact is with front lip you cant really lower more. :p + If you have a lip, the lip will actually protect this piece you see.
Another thing is that I don't think the porsche one would be as effective as this on our car, this is true direct air passage from high pressure area to low pressure area. It's not so different from putting a air duct through your fog light.
Old 09-23-2015, 12:07 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
Overall i'd prefer tougefactory's ducts. They won't scrape, as they are not below bumper like these, and they won't require removing fog lights in upper toyobaru trims, like APR's will, as inlets are near rad, not behind foglight openings. And they direct air directly to disk/caliper.
There is 4th option of one guy making active brake cooling with thermal sensors and electric fan, but that sounds to me like overcomplified overkill. Yes, indeed with such even stock brake thermal capacity will be enough for heavy track use, but i'd rather invest that money to upgrade to BBK, which will bring lightweightness and cheaper wearables too.
Old 09-23-2015, 03:54 PM   #10
Createddeleted
Drives: 2014 BRZ - 2004 GLI
What lip/bumper extension is that?
Createddeleted is offline   Reply With Quote
Old 09-23-2015, 06:28 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Brake ducting is only as effective as the pads you're running.
For street use or throwaway pads, they're fine.
Caveat emptor.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
chaoskaze (09-23-2015)
Old 09-23-2015, 08:19 PM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Those temps are after hard driving? In sub freezing weather I guess?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
CSG Mike (09-23-2015), drewbot (09-23-2015), wparsons (10-30-2015)
Old 09-23-2015, 08:42 PM   #13
Just saying, but I see water on your wheels. If I had been driving (and braking) hard, that water would have evaporated off before I can get out of the car to take brake temps.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
ATL BRZ (09-30-2015), FRSBRZGT86FAN (07-18-2016), SkAsphalt (09-24-2015), wparsons (10-30-2015)
Old 09-23-2015, 11:12 PM   #14
cywinr
Drives: DGM BRZ MT
i'm much more interested in that splitter. do you have a link to that? or better pics?
cywinr is offline   Reply With Quote
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 07:01 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Is there an FRP/urethane brake duct out there? Blizzard Cosmetic Modification (Interior/Exterior/Lighting) 4 12-10-2013 10:31 AM
Brake Duct options? kosoku Tracking / Autocross / HPDE / Drifting 13 08-23-2013 08:45 PM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 06:04 PM
