Old 09-21-2015, 08:49 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
1.0 trd springs alignment specs?
I purchased some trd springs for my 2013 frs and wanted to get an allignment. I was wondering if the 1.0 with trd spring specs would work on my car. I want to lower my car on the springs without ruining that frs tail happy and easy to control flavor.
What must I do to align my car for my preferences? What should I tell the folks that'll align my car?
And I also read that one of the forum members had gotten his aligned as soon as he got the springs installed, and unfortunately, the springs settled much lower after about 3 months...
Astroboy is offline   Reply With Quote
Old 09-21-2015, 09:19 PM   #2
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
drive it least a week before. I replaced mine last week bc one was bent a bit. Getting alignment Sunday.
Packofcrows is offline   Reply With Quote
Old 09-22-2015, 07:24 AM   #3
Astroboy
Astroboy's Avatar
Drives: None
So drive it at least a week? Or less than a week
Old 09-22-2015, 09:46 AM   #4
Packofcrows
At least to give em time to stretch and settle
Old 09-22-2015, 05:06 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
Honestly it took me reading that three times before I understood that 1.0 refers to a car that isn't a 2013 FRS. What is a 1.0 and what are the 1.0 with trd spring specs?
Old 09-22-2015, 06:32 PM   #6
Astroboy
Astroboy's Avatar
Drives: None
It's the limited edition trd frs. Search up "frs 1.0 series"
Sent from my LG-D850 using Tapatalk
Old 09-22-2015, 07:30 PM   #7
Calum
That Guy
The suspension hasn't changed significantly. The dampers are now made by a different company but all credible reports show the damping curves to be similar to the original OEM's dampers. And they changed the bolt head design for a couple of the bolts. So the specs for that work for one FRS will work for another.
That said, what are those specs? And please, don't tell me to search for them. I'm not asking because I'm interested in using them, I'm attempting to offer the help you came here asking for.
Old 09-22-2015, 08:36 PM   #8
Astroboy
Astroboy's Avatar
Drives: None
Alignment specs are what I'm looking for. so are you saying they haven't changed?
Old 09-22-2015, 09:54 PM   #9
Calum
That Guy
The only thing that's adjustable from the factory is toe, unless that limited edition came with camber bolts. But you can get a set of camber bolts for ~$20.
I take it you're looking for alignment specs?
Reading between the lines here, and making some assumptions about your knowledge and the suspension setup you're aiming for, I'm going to say get the camber bolts, and use them to get as much negative camber as you can in the front. I'm guessing you'll max out somewhere between 1.5 and 2 deg. That's fine. Even from side to side is better than max on each side if there's a difference. (there normally is)
You wont have any camber adjustment for the back, but the lowering springs should put you in a good place for rear camber anyway. If it's not even you can either get a set of rear lower control arms or a set of 12mm camber bolts and adjust the rear. Again, even amounts of camber side to side is most important. Your goal for the rear would be about 1.5 deg.
For toe, I'd say go with the factory specs.
Alignment specs Thatguyjeremy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-06-2015 01:49 PM
Autox alignment specs? normanb21 Tracking / Autocross / HPDE / Drifting 18 02-12-2015 07:52 PM
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 06:30 PM
Alignment specs? russv Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-03-2013 10:16 AM
Actual alignment specs from BRZ taosracer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 06-29-2012 09:33 AM
