Drives: Hot Lava 86 MT
Help needed with KW V3 coil overs and RSR pillow ball top mounts
I need some help here since I am losing my mind. I am not a mechanic but have done everything on my car myself, with and without friend's assistance. But this one has me stumped.
I have bought KW V3 coil overs and RSR pillow ball top mounts (front) for my beloved 86. Had everything shipped to Dubai and it has been laying in my man cave for weeks. Finally got to installing them on Saturday but ran into the following problem: I do not know how these go together!! I cannot find any exploded diagram that shows how you put the coil overs and top mounts together. I have found various videos that show how to install, but not putting them together. I have tried every permutation I can think of and need some help, pics below shows what I have to work with: PS: the nut that came with the top mounts do not thread over the shock shaft as it is too big. pretty sure that the nut is the incorrect part. ![]()
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
Drives: 2014 FR-S
Typical assembly goes like this:
spring perch -> spring perch bushing -> pillowball -> shock nut Borrowing from Raceseng: ![]() First thing you gotta do is figure out if you can use the RS-R spring perch. If it is the same diameter as the KW (60mm) then you can. If you can use the RSR spring perch, then you need to swap the KW perch (the top purple conical looking thing). The perch then seats directly into the pillowball, because the bushing and spring perch are a single piece. If you can't use the RSR spring perch, then you'll need to keep the KW and also buy a bushing so it will fit into the pillowball correctly. You will need 15mm diameter bushing. For the shock nut on top, you will need M12 x 1.25mm. Raceseng sells what you need but it is sized properly for the pillowball in their own camber plates. It might work with your RSRs but no guarantees. http://www.raceseng.com/shock-nut-shock-bushing-cascam |
| The Following User Says Thank You to kbye For This Useful Post: | DAEMANO (09-21-2015) |
Thanks for this. I have been travelling so no time to look at this.
I have contacted the supplier I have bought from and also RSR directly a week ago. My supplier only got back to me last night saying he is having difficulty getting hold of RSR and KW. Now that just pisses me off since I am in Dubai and they are in the US. Surely he can get hold of them. From the image you posted I need to find the correct spring perch bushing and top nut. Both of mine do not work with the KW but the RSR website states they will work with OEM shocks. And the KW will work with the OEM top mount so not sure why they do not work. The shock shaft of the KW and OEM is identical so that leaves the RSR being my problem.
| Beatrush Pillow Ball Mounts with KW V3? | digital_assassin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 09-07-2015 11:21 PM |
| Feeler: ST coil overs with white line mounts | Proof | Brakes, Suspension, Chassis | 11 | 06-12-2015 10:59 PM |
| FS (GA) Tein Street Flex Coilover Adjustable w/ pillow ball mounts | GTHachiRoku | Brakes, Suspension, Chassis | 11 | 09-28-2014 10:09 PM |
| Im buying coil overs within the next 2 days i need help deciding what coil overs | Anthony7515 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 06-30-2014 08:47 AM |
| Im buying coil overs within the next 2 days i need help deciding what coil overs to | Anthony7515 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 06-27-2014 01:00 PM |
