Old 04-13-2013, 12:05 PM   #1
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Beatrush Pillow Ball Mounts with KW V3?
I've been looking around for options for Pillow Ball Mounts for us KW V3 users and understand the GD styles should work. I am looking at the Beatrush plates and can't find any information as to whether they will work for the KW V3's which I believe have a 60mm spring. Anyone with experience or insight please chime in, I don't want to drop over $300 and find out they won't work.
http://www.rallysportdirect.com/Beat...rce=GoogleBase
http://www.laile.co.jp/eng/product/p...6TMFPAeng.html
@RallySport Direct - Can you look into this? I chatted for a few seconds with a fellow named Sterling but had to bolt and figured I would get more insight on here.
digital_assassin is offline   Reply With Quote
Old 04-13-2013, 12:11 PM   #2
eckoflyte
Drives: Toyota 86 GTS
why not just get the vorshlags? they're well priced, known for their proven quality and reliability amongst the aftermarket community, have added caster offset, and fit the KW V3.
eckoflyte is offline   Reply With Quote
Old 04-13-2013, 12:15 PM   #3
digital_assassin
Vorshlag plates are an excellent option. I just want to know if we have other options. Beatrush makes quality parts and these seem to be pretty stout and cost $100 less.
Old 04-15-2013, 01:37 PM   #4
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
I was trying to confirm 100% for you, but could not find conformation. Now I would imagine these will work without any issues at all, as the KW's are designed to use the OEM top hats, and these Beatrush top hats are designed to work with the OEM dampers. I will keep on digging around for you, but just wanted to jump in here with an update
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 04-15-2013, 01:58 PM   #5
digital_assassin
Thanks Rick! I emailed Laile and got this back...
"Thank you for your interesting in our products.
If you can inform us the screw size of pillow nut,
we can make it for you,
Thank you,
Hamada/ Laile"
I appreciate you looking into this. They're installed on the Beatrush 86. You can see them in all the pictures of the Type 1 & 2 strut bars. If you can confirm this works please send me a PM for pricing of the plates and the Type 1 bar purchased together.
I really like the product Beatrush puts out. Do you know if they are going to do a master cylinder brace for LHD cars. I've noticed they've recently released some cross member inserts and a really nice diff brace so it seems as they are making progress on this platform.
Old 04-16-2013, 02:17 PM   #6
digital_assassin
@RallySport Direct - you ready to take my money yet Rick?
Old 04-16-2013, 04:06 PM   #7
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
JDL Auto Design have KW V3 coilovers with Hotchkis camber plates on their FR-S. The Hotchkis plates add 1° of positive caster and you can get up to 3° of negative camber. The plates slide, so you can adjust camber to whatever angle you wish within it's range. Just another option.
http://www.hotchkis.net/scion-frs-su...er-plates.html
Nitro22 is offline   Reply With Quote
Old 04-16-2013, 04:07 PM   #8
RallySport Direct
I was not able to get a conformation from Beatrush, but doing my own research, the KW's will use the OEM thread pitch and diameter which should be 12x1.25. The Beatrush camber plates will also use a 12x1.25 nut, so those should work together without an issue.
I don't think Beatrush will produce the Strut bar with the master cylinder brace for the LHD models, but we do offer the cusco one, or an independent MC brace as well
Also, I will PM you a price on the Strut tops and strut tower bar
Thanks,
Rick
Old 04-17-2013, 09:52 AM   #9
digital_assassin
@RallySport Direct - Hey Rick. I did some digging last night and came upon a blog for the Laile parts development. Once again the translation sucks on google chrome but at the bottom 2 blog entries of this page you can see what Laile mounted up to their car. In your opinion does this still look like a go? I'm no suspension GURU so your advice is appreciated.
Old 04-17-2013, 11:11 AM   #10
Racecomp Engineering
They should fit but you may want to use the GD OEM conical washer.
- Andy
Old 04-17-2013, 12:51 PM   #11
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Anyone know how to add camber adjustment without using camber plates?
I am interested in getting V3s but don't want to suck up the cost of spending another 400+ for camber plates.
shu5892001 is offline   Reply With Quote
Old 04-17-2013, 12:56 PM   #12
digital_assassin
You can get a fair amount just from the slots in the front struts. If you need more just add camber bolts. Only reason to go with the plates with the KW's is a more connected feel from omitting the rubber in the OEM top hat and ease of adjusting for different scenarios.
Old 04-17-2013, 02:03 PM   #13
digital_assassin
So my next question would be has anyone outside of Japan actually seen and used these and is there a obvious benefit by choosing the Vorshlag plates over these.
If I go with Beatrush plates I will also do the Perrin PSRS busing to stiffen that point up and get some more caster whereas the Vorshlag has added caster built in but I would still be using the OEM bushing in the control arm.
I found a picture of the Vorshlag plates and it appears they have 2 bearings instead of just the one. What is the benefit of this over 1 bearing? Does it increase the life of the set up or does it function markedly better or simply cut down on noise?
My goal is to track the car. Quality of the parts is very important. I don't want to waste money on plates that will fail is my ultimate concern.
Old 04-17-2013, 02:06 PM   #14
RallySport Direct
- Andy
Yep! I am with RCE on this one, and I forgot to mention the conical washer before, but you can pick that up from the dealership
PS. I stole this picture from Myles post, but here is the OEM conical washer:
@digital_assassin Nailed it. If you need more camber than stock can provide, you will want to get an aftermarket set of camber bolts to help dial in the camber.
Thanks,
Rick
KW V3 and pillow ball DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 09-29-2015 06:44 AM
Beatrush intake kit digital_assassin Engine, Exhaust, Transmission 16 04-06-2013 01:19 PM
Scion FR-S Pillow! DBacon1052 Scion FR-S / Toyota 86 GT86 General Forum 26 10-15-2012 04:38 PM
Scion Drops the ball... dcaff Scion FR-S / Toyota 86 GT86 General Forum 402 12-14-2011 12:40 PM
Watch this on your next ball game 4agze Off-Topic Lounge [WARNING: NO POLITICS] 4 10-03-2011 04:55 PM
