Drives: Subaru BRZ Limited
Stock Caliper pass, BBK Drivers?
So trying to troublshoote some strange noise, anyone have any insight if i could put a factory caliper and rotor on one side, and then bbk on the other, this will help me determine what side is causing the issue?
wouldnt drive on it much, other than a couple blocks to see if noise goes away. |
Thanks
Just jack up the front and Have someone spin the wheel by hand and be in the car to operate the brake pedal.
Hell of a lot less work.
Cannot spin the wheels by hand fast enough to replicate. Need to be going around 10-15
| Stoptech S/S brake lines: same between stock caliper vs big brake kit? | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-10-2016 07:14 PM |
| Drivers side Brake caliper stuck shut? ABS engaged all the time. | gdrider77 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 09-20-2015 09:02 PM |
| FRS/BRZ Affordable OEM Caliper BBK - Larger Rotors with Stock Calipers! | RB Performance Brakes | Brakes, Suspension, Chassis | 60 | 08-11-2014 02:01 PM |
| Stock caliper model? | skoodge | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 05-31-2012 08:41 PM |
