Old 09-12-2015, 08:28 PM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Drivers side Brake caliper stuck shut? ABS engaged all the time.
Running wilwood bbk up front.
So just 2 days ago, i was driving and any time i press on the brakes with forward momentum, i believe the ABS is kicking in. It immediately makes a studdering/shuddering sound. If i revers and brake, no problem.
I pulled the wheels off, inspected the rotors, pulled the pads, inspected all looks good. What i noticed is up on the lift, the pass wheel freely spins, so lets call that 0% brake engagement, with the typical minor rotor/pad rubbing.
Drivers i would say is 80% engaged, takes a lot of force to get the tire to rotate, and even then, does not spin, as the rotor and pads are essentially engaged.
Its making me think that this is the reason for the sound when braking, since the drivers side is almost completely engaged already, as soon as i brake, abs sees that as being locked up and engages.
I took some video and will try to post shortly, have to see if its even good enough quality to hear problem.
Is there a way to completely eliminate the ABS to check without it? I tried pulling both fuses, but that didnt seem to make a difference.
Trying to trouble shoot, maybe possible the ABS unit is bad? Or thinking that maybe the caliper is going bad, starting to seize.
About 3 days agao i was driving and came around a corner and had to quickly brake, maybe 65 down to 30, it locked the tires, not sure if that did something. It didnt start up righat after that though, it wa a day later that i noticed this.
gdrider77 is offline   Reply With Quote
Old 09-12-2015, 08:48 PM   #2
juliog
juliog's Avatar
Drives: 86
Sounds like a seized caliper? Disassemble caliper, apply high temp brake grease to slider pins. I would recommend doing a full caliper rebuild while you're at it (cleaning piston surfaces, replacing seals, slider pin boots..). Google caliper rebuild kit for this car.
juliog is offline   Reply With Quote
The Following User Says Thank You to juliog For This Useful Post:
gdrider77 (09-12-2015)
Old 09-12-2015, 09:18 PM   #3
gdrider77
gdrider77's Avatar
Yeah, seems like a seized caliper to me as well, im gion gto pull that off tomorrow and check it, lube it, etc..Its less than a year old, and probably has about 2500 miles total on the caliper, so not too happy about that.
Old 09-13-2015, 01:02 AM   #4
gdrider77
gdrider77's Avatar
No slider pins on these calipers, but going to rip it apart tomorrow and clean / lube the pistons.
Old 09-13-2015, 02:26 AM   #5
juliog
juliog's Avatar
Drives: 86
There are slide pins. Check the caliper Rebuild Guide:
http://www.ft86club.com/forums/showthread.php?t=60896
Edit: NVM realized we're talking about after market BBK
Old 09-13-2015, 07:11 AM   #6
stevesnj
stevesnj's Avatar
Could be a caliper piston got stuck.
My 2016 Build thread
Old 09-13-2015, 05:29 PM   #7
gdrider77
gdrider77's Avatar
Pulled the whole caliper off, pulled the pistons, cleaned them, relubed and resinstalled, as well as bled the brake system. Seems to have helped just a bit.
The wheel now freespins a few revolutions, same as pass, so in that regards, the piston sticking seems to have been fixed. But, the ABS still seems to be engaging on any braking.
At this point, i guess next step is to get a new abs controller and swap that out. ugh.
The Following User Says Thank You to gdrider77 For This Useful Post:
stevesnj (09-13-2015)
Old 09-13-2015, 05:53 PM   #8
juliog
juliog's Avatar
Drives: 86
Have you considered putting OEM calipers back on?
Old 09-13-2015, 07:20 PM   #9
gdrider77
gdrider77's Avatar
Yes, i might try that. Problem is you have to modify the brake line mount to fit the wilwood, and not sure if it will be real easy to put back, but i will possibly try that as my next next.
Old 09-13-2015, 09:35 PM   #10
Turdinator
Señor Member
Turdinator's Avatar
It sounds more like a warped rotor to me. If you pull the fuse the ABS can't work. If the calliper was seized its not hard to imagine the extra heat warping the rotor.
1974 TA22 Celica
2013 86 GT
Old 09-13-2015, 10:41 PM   #11
gdrider77
gdrider77's Avatar
I could see that, especially to the point of the abs fuse being pulled. I pulled both the 40 and the 25 amp fuses, and it does the exact same thing, so maybe its not the ABS, and its actually the rotor being uneven and causing the strange sound.
Maybe i will pull the rotors and check for uneveness. Not great, but a quick fix if i just replace a rotor, like $200 bucks.
Old 09-14-2015, 01:25 PM   #12
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Make sure they're well bled as well...I've seen calipers with air in them that start to grab the rotor when they heat up and the air expands.
venturaII is offline   Reply With Quote
Old 09-17-2015, 12:26 AM   #13
gdrider77
gdrider77's Avatar
i ordered a complete rebuild kit, new rotors and some other items. Im going to try a few things this weekend and see what i can find.
Old 09-17-2015, 02:17 AM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Have you checked to make sure that your hat to ring bolts are all tight?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
gdrider77 (09-18-2015), stevesnj (09-17-2015)
Brake Rotors: Rusted Stuck Apex_BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-21-2019 03:40 PM
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 07:14 PM
Simple Shut Window Feature Not Working on Driver's Side Gimagination Issues | Warranty | Recalls / TSB 21 05-08-2013 11:59 AM
How to mod Auto headlights shut off time? JSUB BRZ First-Gen (2012+) — General Topics 12 02-02-2013 12:48 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
