Drives: 2005 Toyota Camry
Stoptech S/S brake lines: same between stock caliper vs big brake kit?
I'm checking pictures and was hoping someone can verify:
Stoptech Big Brake Kit for FRS/BRZ: front stainless lines, are they the same as the standard off-the-shelf stainless line upgrades for factory calipers? @FT86SpeedFactory pics from their big brake kit sales thread: versus... @RallySport Direct pics from their front stainless line (factory caliper) listing on their site: ![]() The part numbers are the same... can anyone verify? Also: for other big brake kits, do they also reuse the factory banjo fitting? Thanks in advance. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Sportsguy83 (10-09-2013) |
#2 | |
I Love custom Turbo kits
Drives: Limited BRZ
Just got off the phone after talking with Roger from Stoptech. He said the lines are different. The ones included in the BBK are specifically made for their caliper. What we can do is I can send you my "for stock caliper" goodridge lines and you send me the ones included in the BBK kit (just like we are doing with the Pads). Good thinking! Sounds like a plan?
#3 | |
I'll put the BBK lines in the box. -alex |
#4 | |
Drives: Limited BRZ
He sounded extremely confident. Like immediately told me no, they are not the same. Sent from my HTC One X using Tapatalk 4
#5 | |
Boosted
Drives: Not a supra....yet
| The Following User Says Thank You to SmsAlSuwaidi For This Useful Post: | Sportsguy83 (10-09-2013) |
This probably doesn't help, but the Speigler lines we sell work for most BBK as well as the stock caliper.
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | mav1178 (10-09-2013), Sportsguy83 (10-09-2013) |
#7 | |
Interesting. Will dig into this deeper and report back. -alex |
I believe the stock (and spiegler) is a banjo fitting, but I don't know the technical terms for a lot of parts...
#9 | |
A lot of aftermarket calipers and/or previous OE 4 piston calipers (see: Nissan Z32 and Z33) uses flare fittings, similar to what goes into the brake master cylinder. http://www.eastwood.com/Brake_article for what they look like. I only care about this because it may come in handly for those of us looking to jump up to larger brakes, but already have stock caliper S/S line upgrades. -alex |
#10 | |
Drives: Limited BRZ
I STILL call BS on this because how can you control this with same part number, but will be installing the Stoptech lines just to err on the safe side.
#11 |
Drives: Crystal Black BR-Z Limited
Just got off the phone with Stoptech. I called in just referencing the part number, not the vehicle, for our cars which is 83.827.4300.xx which is the ST40 328mm front kit. I asked what the SS line replacement part number was and they said 950.44034. I then proceeded to ask what the replacement lines for 83.827.002G.xx (rear ST22 345mm kit) were and they said 950.47508.
I then asked what the part numbers were for the BR-Z and FR-S stock SS lines. SAME. They are the same part. It's not a common thing but in this situation the stock lines and the BBK lines from Stoptech are the same. I spoke with Roger. |
| The Following 3 Users Say Thank You to Excelerate For This Useful Post: |
#12 | |
Drives: 2013 - BRZ - SWP
| FS: Stoptech SS Brake Lines | xman11 | Brakes, Suspension, Chassis | 6 | 08-12-2013 01:53 PM |
| FRS/BRZ StopTech Brake Pads, Rotors and Lines at Redline360 | Redline360 | Brakes, Suspension, Chassis | 4 | 01-13-2013 02:42 AM |
| FS: Stoptech Brake Lines | FRS2000 | Brakes, Suspension, Chassis | 1 | 12-17-2012 04:07 PM |
| Stoptech Front Stainless Steel Brake Lines | Pekingduck | Brakes, Suspension, Chassis | 1 | 10-21-2012 10:29 PM |
| StopTech Stainless Brake Lines (Front and Rear) for BRZ/FR-S at Redline360 | Redline360 | Brakes, Suspension, Chassis | 1 | 07-19-2012 01:41 PM |
