Old 09-18-2015, 09:49 PM   #1
SrgtSnuggles
Drives: Track oriented BRZ
Transmission issues
Hey guys I had a quick question. So my friend just got a 2013 brz with 20000 miles on it (5000 more then mine) and his shiftier feels a lot crisper then mine. I do track mu car a lot and I have changed out the stock transmission fluid through the dealer but should I worry about this. I'm just worried that because I track the car so much I've damaged the synchros or something. It shifts fine and I've never really grinded the gears. Its really just easier to get into gear really and doesn't feel as notchy. I also heal toe when I'm on track if that's any consolation.
SrgtSnuggles is offline   Reply With Quote
Old 09-18-2015, 09:54 PM   #2
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Have you changed the diff fluid out?
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 09-18-2015, 10:07 PM   #3
joe strummer
What does the differential have to do with transmission shifting feel?
joe strummer is offline   Reply With Quote
Old 09-18-2015, 10:38 PM   #4
SrgtSnuggles
Yes I do a full fluid change every year but I'm due for one
Old 09-18-2015, 10:52 PM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
You had the dealer change your tranny fulid? Well, that may be the issue right there.
Does your buddy have the trd quick shifter and better fulid? Like redline or motul? If so there's your answer.
Old 09-18-2015, 11:00 PM   #6
SrgtSnuggles
No his car is completely stock and never been touched. I was thinking about having them put the motul fluid in. Will that void the warranty through if i dont use their fluid? I guess maybe they just put in some bad fluid
Old 09-18-2015, 11:26 PM   #7
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Voild the warranty? Oh hell no. As long as you put in the factory recommended spec of oil your good. Any and I mean any brand of oil as long as it meets the factory specs you can put in. If they give you any lip, get the fuck far far away from that dealer with one finger wave goodbye.
My guess is that they never changed out your tranny fluid.
FYI there was a class action lawsuit which gives us the consumer the right to use any fluid we want with out voiding warranty. That was back in the '70s if I recall. Some one might chime in on that.
Old 09-18-2015, 11:40 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
Oddly, was going to refer to @Aztec's car anonymously but then I saw his post.
I think the behavior of these transmissions vary greatly from one unit to the next. IIRC, we have similar build dates but his is MUCH less picky than mine. Both of our transmissions are in great shape but his syncros grab harder with significantly less force applied.
It might be a break-in thing as well. I'm typically quite gentle with mine. It only humbles me when I try to show off.
transmission
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 06:17 PM
Transmission issues (or me being too anal) Pkush Issues | Warranty | Recalls / TSB 18 12-06-2014 10:43 PM
manual transmission issues. DriftEightSix Engine, Exhaust, Transmission 24 06-10-2013 08:25 AM
manual transmission issues XtremeMaC Engine, Exhaust, Transmission 4 10-10-2012 06:40 PM
Transmission issues... Rob_g Issues | Warranty | Recalls / TSB 13 09-23-2012 07:40 PM
