Old 09-16-2015, 11:35 AM   #1
1Cor10:23
1Cor10:23's Avatar
Replacing oil cooler line fittings?
Hi All,
I've got a situation where I likely have faulty female hose-end fittings for my oil cooler. I'm wondering if it's advisable to remove them (seems to be clamped with a metal band - easy to remove?) and put in new fittings into the existing hose and then tighten with zip ties.
Asking as it's a much easier fix to do than replacing the entire hose and fittings on both ends. They are clamped on the same way that Perrin does their fittings.
@PERRIN_Chris would love to get your thoughts on this - is it easy to swap fittings at the hose female AN hose end where it connects to sandwich?
Would greatly appreciate any advice!
Old 09-16-2015, 07:09 PM   #2
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
The fittings on the PERRIN oil cooler lines are really tight! They're a special style fitting and hose to make it seal on the hose even without the clamp. We include the clamp just as a backup. This makes it pretty much impossible to take them off the hose once they're installed, so you will have to cut them off, shortening the hose.
Replacing the fittings on the thermostat side is easy though, they just unscrew from the thermostat. Hope that helps some!
PERRIN_Chris is offline   Reply With Quote
Old 09-16-2015, 08:53 PM   #3
1Cor10:23
1Cor10:23's Avatar
@PERRIN_Chris aww darn, the hoses were cut to length, don't think I can shorten them by the 2 inches that procedure would require. Ah well, thanks for saving me the trouble!
Old 09-17-2015, 12:26 AM   #4
humfrz
Originally Posted by 1Cor10:23 View Post
Hi All,.............
... put in new fittings into the existing hose and then tighten with zip ties.
On the side, I wouldn't trust zip ties to hold any hose in place ......
humfrz
Old 09-17-2015, 01:43 AM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
humfrz
+1
Bozos on my FSAE team wouldn't listen to me when I warned against using a barbed fitting and hose clamp for an oil line.
They spewed oil all over the track during the <cough> endurance event.
Oil Cooler Line Question Dezoris Engine, Exhaust, Transmission 18 11-08-2016 06:02 AM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
Aeroquip socketless AN fittings / hose question brillo Engine, Exhaust, Transmission 1 07-14-2013 07:31 AM
Dual Catch Can, hoses and fittings Sportsguy83 Engine, Exhaust, Transmission 9 02-21-2013 01:13 AM
