Old 06-17-2014, 04:11 PM   #1
Dezoris
Dezoris's Avatar
Oil Cooler Line Question
I am at my end with this whole oil cooler line nonsense.
First after winter, I had a leak from the flared fittings at the sandwich plate.
Perrin sent me new lines.
I re-installed, and had no issues but then I had a leak from the mocal rubber sandwich plate gasket.
So I ordered a brand new mocal plate and Perrin sent me new O rings for their spacer. Installed and now the fuking flared fittings are seeping underneath again from the lines. I am using a paper tower rubbing underneath fittings and their is fresh oil, very little.
I tried installing where fittings screwed on easily then hand tight then snugged them. Leaked. Then really tightened them, same crap.
They are flared fittings, not rocket science but can't understand what the hell I am doing wrong here. Any advice?
Old 06-17-2014, 05:31 PM   #2
vroom4
Terry at @Maximal can probably hook you up with a different style fitting/line.
vroom4 is offline   Reply With Quote
Old 06-17-2014, 05:45 PM   #3
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Starting to feel your pain with your oil cooler problems man. Hope you sort it out soon!
Tye300 is offline   Reply With Quote
Old 06-17-2014, 06:38 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Thread sealer?
Old 06-17-2014, 06:44 PM   #5
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
why not try a different brand of AN fitting? can you see the impression of the cone sealing face on the end of the AN adapter from the plate?
Speedflow sells AN caps that fit on the cone face to seal damaged fittings
JP is offline   Reply With Quote
Old 06-17-2014, 11:53 PM   #6
Dezoris
Dezoris's Avatar
Originally Posted by Draco-REX View Post
Thread sealer?
Not recommended for flared AN fittings.
Old 06-17-2014, 11:53 PM   #7
Dezoris
Dezoris's Avatar
Ordered conical washers as you mentioned. If its good for aviation should be good enough here.
Old 06-18-2014, 12:33 AM   #8
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
AN fittings are designed to be snug but not as tight as you'd expect for threading as large as they are. I believe the Perrin cooler comes with -10 AN which you'd want to tighten to around 33±3 lb*ft. You can use a crow foot on a torque wrench or hand tighten to snug then tighten an additional quarter inch. The flared fittings are anodized aluminum right? Check the surface of the flare and cone and see if they are marred up or scratched as JP mentioned. It should be obvious since they start black. If they are good, try tightening using those specs/method and see if it leaks, otherwise try the washers.
zkv476 is offline   Reply With Quote
Old 06-18-2014, 01:14 AM   #9
stugray
Drives: 2013 GBS BRZ Limited
The washers for sealing are called "del seals"
http://www.delaerospace.com/files/23000507.pdf
Old 06-18-2014, 01:20 AM   #10
Fastbrew
Drives: 2014 Pearl White BRZ
Noted - it makes me want to take a better look at the Cusco water cooling system as opposed to this.
Fastbrew is offline   Reply With Quote
Old 06-18-2014, 01:25 AM   #11
JP
Backyard Fabricator
with quality fittings you wont have any leaks. The QC isn't always perfect on the China/TW sourced fittings.
Old 06-18-2014, 01:26 AM   #12
zkv476
zkv476's Avatar
I run the OEM Forester XT oil-water cooler from the 2.0DIT which I believe is very similar to the Cusco system (and a heck of a lot cheaper) and it works pretty well. One thing to note is that since they inherently operate off temperature deltas the temps will be a little higher than those of thermostatic air-oil coolers. Upside is that no worry of damaging the cooler and springing a leak since there's no front mount air-oil unit and it doubles as an oil warmer on cold startup . It should be adequate for most DD and light autoxers like I plan to be. I will be installing a Vortech SC soon too.
The answer is racecar. Always.
Old 06-18-2014, 12:15 PM   #13
Dezoris
Dezoris's Avatar
Perrin uses Aeroquip fittings which from what I understand are quality.
http://aeroquipperformance.com/p-24061-fittings.html
I used an aluminum wrench for tightening to avoid damaging them as well.
Was very careful installing lines, just must have a run of bad luck.
Going to install the conical washers and report back.
Old 06-18-2014, 02:26 PM   #14
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Dezoris, it could be that the oil is coming from the inside the fitting, and when tightened up, and the car heats up for the first time, a few drips out, but then it should stop.
It also could be there is a burr on the inside of the fitting where it seals to the male fitting. If that happens, the fitting will never seal right, since it's a mechanical seal, and it'll continuously leak.
PERRIN_Chris is offline   Reply With Quote
Catch Can breather line question protpibe Engine, Exhaust, Transmission 1 01-18-2014 03:20 PM
STI Brembo Gold 2003+ brake line question Trap63 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-10-2013 11:06 AM
Technical question about oil cooler solma Engine, Exhaust, Transmission 5 05-27-2013 08:54 AM
Cheap/Crafty Oil Cooler question. Asterisked Accolade Tracking / Autocross / HPDE / Drifting 8 04-07-2013 10:45 PM
Question about Greddy oil cooler Captain Snooze Engine, Exhaust, Transmission 3 09-10-2012 03:40 AM
