| CANADA Canada |
Send a Canadian BRZ to SEMA
hey guys,
I'm not sure if you guys know of PASMAGs Tuner Battlegrounds, but it's in it's final stages. My car is currently in the Top 32 which is their "bracket style" tournament. It's essentially an online vote farming session where they rack up tons of exposure at the expense of people who salivate over the prospect of going to SEMA lol. Voting is done daily on my PASMAG profile page and is monitored via Facebook credentials. Each round goes for 1 week and resets every Monday @ noon. The winner of the bracket moves on to the next, etc etc. I'm on Round 2 of 5. If you have a spare minute or two and wouldn't mind helping a guy out, i would appreciate the support! And for the haters, it's built not bought lol. All work done by me in my garage ![]() Here is the link to vote: http://bit.ly/alexdbrz For those wondering if my car should be at SEMA or not, here is the build thread: http://toptierimports.com/index.php?topic=6476.0 - I'm not trying to sound arrogant, but i believe it to be one of the most comprehensively modified twins in Canada. Pics ![]() Build Thread (as per request) - 800+ replies, 40,000+ views on the local Winnipeg import forumhttp://toptierimports.com/index.php?topic=6476.0 And parts list: Current Mod List: *Updated 09/15/2015 Suspension, Brakes, and Wheels 17x9" +35 GramLights 57DR Gun Blue Project Kics R40 Black Lugs 245/40/17 Continental Extreme Contact DW HKS Hipermax Max IV GT Coilovers Buddy Club front control arms with racing ball joints Buddy Club rear lower control arms Hotchkis Front and Rear Sway Bars Perrin control arm braces Whiteline rear sway bar braces Whiteline rear end links Whiteline camber bolts Whiteline rear subframe bushings StopTech front/rear stainless steel brake lines Motul 600 brake fluid Motul 300v 0w20 oil Motul Gear 300 75w90 for Transmission and Differential STI Brembo Front and Rear brake calipers Hawk HPS Front Brake Pads Hawk HPS Rear Brake Pads DBA T3 4000 Slotted Front Rotors DBA T3 4000 Slotted Rear Rotors KNS Brake rear caliper brackets Speedbleeders AVO Anti-Tramp rear differential bushing inserts 18" x 9.5" Enkei RS05RR in Matte Gunmetallic 265/35/18 Michelin Pilot Super Sport Kics Iconix black lugnuts Ichiba hubcentric spacers 10mm with extended studs (front) 5mm hubcentric spacer (rear) H&R Trak 30mm Spacer (Front) Blox 60mm Spacer (rear) Air Lift performance Front struts Air Lift performance Rear struts Airt Lift Autopilot V2 air managment Accuair 5gal air tank (powdercoated gunmetal grey) Custom DOT approved PTC 1/4" air fittings (bulkhead) Engine and Drivetrain Perrin Light Weight Water pump and Alternator Pulleys Perrin Master Cylinder Brace Whiteline Transmission bushings MTEC Shifter Springs Kartboy Short shifter + Bushings ECUTEK Cable + License AVO Stage 1 Turbo Kit AVO 50/50 Blowoff Valve AVO Crossover Pipe (Ceramic Coated) GrimmSpeed hood struts GrimmSpeed exhaust gaskets AEM Boost/AFR Failsafe Gauge Innovate MTX-L Oil Pressure/Temp Gauge Block8Head Custom defrost vent gauge mount ATI Vent Pod gauge mount Blitz EU GT86 specific Oil Sandwich plate with spacer Grimmspeed black engine cover Vibrant T-Bolt Clamps Vibrant Vacuum Manifold Vibrant Hose Clamps Spencer Fabrication custom vent hard lines Treadstone turbo blanket ProSport remote oil pressure line Custom dual catch can setup made by Saikou Michi Perrin 3" Catback Exhaust AVO 3" Downpipe AVO 3" Ceramic Coated Overpipe AVO 3" Ceramic Coated Front Pipe (no cat) Perrin Cold Air Intake in Black Delicious Tuning ECBS Delicious Tuning Speed Density Tune (4 maps) Target Based Boost Control Full Blown Motorsports Oil Cooler Exedy Stage 1 Clutch and Flywheel Full Blown Fuel Pump setup with Warlboro 485 DW 450cc Port Injectors Omni 3 Bar Map sensor Gates Racing V-Belt Full Blown Motorsports Aluminum Radiator Full Blown Motorsports Aluminum rad shroud Dual SPAL rad fans Chase Bays coolant overflow tank AVO upgraded 8 PSI actuator P-Tuning Water/Meth Injection Kit with lightweight battery mount Odyssey PC680 Battery Fragola Oil Cooler Lines Spencer Fabrication throttle body spacer and WMI injection plate Cusco Liquid-to-Liquid oil cooler STI Engine Mounts Cusco Air/Oil separator IAG billet aluminum master cylinder Cap IAG billet aluminum clutch reservoir cap IAG billet aluminum complete dipstick replacement IAG billet aluminum washer fluid reservoir cap Prova aluminum oil cap Apexi coolant cap Raceseng aluminum oil filter cover APR Carbon Fiber cooling plate GReddy Profec II Electronic Boost Controller Interior, Audio, and Aero LED Conversion for all bulbs in the car (plate, interior, trunk) Amber LED front signal indicators 35% Tint Toms JDM red tail lights Hella Supertones Perrin aluminum shorty antenna Grimmspeed front license plate bracket STi JDM rear wing gurney flap STi JDM Push Button Start Alpine PDXF4 JL C3 650 Speakers (front) JL C2 350 Speakers (dash) JL C3 650 Speakers (rear) JL 10" WS3 Subwoofer JL sealed subwoofer enclosure Dynamat Extreme Weathertech All Season Mats Backup Camera Debadged rear Cusco aluminum E-Brake knob Eur Toyota OEM arm rest Aus Toyota OEM Black interior conversion Rexspeed convex and polarized rear mirrors Subaru Autodimming Homelink Mirror Cipher Harness Bar Takata Drift III Harnesses in Black (driver and passenger) CaFi Dashlinq4 Toyota Universal headunit DAMD Carbon Fiber core steering wheel Prova shift knob Custom hand made carbon fibre 3rd brake light relocation Password:JDM Carbon Fibre 3 Piece front splitter Password:JDM Carbon Fibre Side Skirts Aero Jacket 1 piece carbon fibre trunk lid with duckbill spoiler Driver and passenger Bride RO BRZ specific rails Edirb 023 red stitch seats (driver and passenger) Seibon carbon fibre hood type DV Diode dynamics 6k HID headlight bulbs Move Over Racing front bumper quick release kit Longacre black adonized splitter support rods Valenti smoked side markers JDM Subaru Fog light housings (DRL Deletes) Prova fender vents OLM Vision+ DRL LED fog light housings and LED foglights KMO Activities Todoroki front 30mm fenders (being painted) GReddy Rocket Bunny V2 side skirts (on order) GReddy Rocket Bunny V2 rear over fenders (on order)
Drives: 2013 WRB Subaru BRZ Sport-tech
voted.
Drives: '15 Halo FR-S
Normally, I don't vote in this stuff, but I'm so fucking jealous of your plate, that you get my vote.
#4 | |
You mean my jets license plate??
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Wow the Jets plate looks way better/cooler than the usual Leafs plate
-Leafs fan |
Drives: 2013 Brz C38 (bought not built :P)
I started reading the mod list, then I scrolled all the way down saw how long it was and gave up. in all seriousness really nice car, I'll vote for it when I get home tonight. Just for shits and giggles how much have you put total in that car?
#8 | |
You should see my Toyota Echo ice racer lolVotes are open to everyone again today (they are reset daily). I'm currently 8 votes back of the guy ahead of me, so I would appreciate if you guys took a minute to vote here: http://bit.ly/alexdbrz
#10 |
A Demon
Drives: Raven GT86
I wish I could vote for you, car's amazing but I don't have a Facebook.
#11 |
Drives: 2017 Toyota 86
Voted, car is beautiful my friend! Wish I had "north of 50K" to spend on the car lol
#12 |
Beautiful car sir! Voted!
#13 |
❤ fr-s love ❤
Drives: 13 Asphalt Scion FRS
So impressed by this none widebody build, always have appreciatation for non-widebody, really well done cars.... then saw the additions on the bottom of the list....
Good luck, voted and I will hopefully see you at SEMA!
Asphalt Scion FR-S Enkei | Aero Jacket | BC Racing | Invida | AFE | JL Audio | Seibon | Chargespeed | Cusco | Mishimoto | Spec D | www.themodmarket.com |
#14 | |
Fit my tire setup with air bags so I got todorokis. Although they look good, the back Looks disproportionately narrow so I went rb v2 sides. I'll be getting them moulded on to clean up the "rivet look" if need be
| cant send private messages | Lithium | Site Announcements / Questions / Issues | 0 | 03-21-2015 06:07 PM |
| Need a favor from a Canadian BRZ owner, (Canadian Base model with Manual Trans)) | boomslang | CANADA | 1 | 09-07-2014 11:24 PM |
| Will someone please send me a datalog? | ATSAaron | Forced Induction | 48 | 09-10-2013 10:29 PM |
| I can't send and receive PMs | Hanakuso | Site Announcements / Questions / Issues | 1 | 06-14-2012 02:08 PM |
| TO ALL MY CANADIAN FRIENDS - BRZ Canadian Pricing Released | zex | BRZ First-Gen (2012+) — General Topics | 7 | 04-24-2012 12:46 AM |
