CANADA Canada
Old 09-15-2015, 07:12 PM   #1
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Send a Canadian BRZ to SEMA
hey guys,
I'm not sure if you guys know of PASMAGs Tuner Battlegrounds, but it's in it's final stages. My car is currently in the Top 32 which is their "bracket style" tournament. It's essentially an online vote farming session where they rack up tons of exposure at the expense of people who salivate over the prospect of going to SEMA lol.
Voting is done daily on my PASMAG profile page and is monitored via Facebook credentials. Each round goes for 1 week and resets every Monday @ noon. The winner of the bracket moves on to the next, etc etc. I'm on Round 2 of 5.
If you have a spare minute or two and wouldn't mind helping a guy out, i would appreciate the support! And for the haters, it's built not bought lol. All work done by me in my garage
Here is the link to vote: http://bit.ly/alexdbrz
For those wondering if my car should be at SEMA or not, here is the build thread: http://toptierimports.com/index.php?topic=6476.0 - I'm not trying to sound arrogant, but i believe it to be one of the most comprehensively modified twins in Canada.
Pics
Build Thread (as per request) - 800+ replies, 40,000+ views on the local Winnipeg import forum
And parts list:
Current Mod List: *Updated 09/15/2015
Suspension, Brakes, and Wheels
17x9" +35 GramLights 57DR Gun Blue
Project Kics R40 Black Lugs
245/40/17 Continental Extreme Contact DW
HKS Hipermax Max IV GT Coilovers
Buddy Club front control arms with racing ball joints
Buddy Club rear lower control arms
Hotchkis Front and Rear Sway Bars
Perrin control arm braces
Whiteline rear sway bar braces
Whiteline rear end links
Whiteline camber bolts
Whiteline rear subframe bushings
StopTech front/rear stainless steel brake lines
Motul 600 brake fluid
Motul 300v 0w20 oil
Motul Gear 300 75w90 for Transmission and Differential
STI Brembo Front and Rear brake calipers
Hawk HPS Front Brake Pads
Hawk HPS Rear Brake Pads
DBA T3 4000 Slotted Front Rotors
DBA T3 4000 Slotted Rear Rotors
KNS Brake rear caliper brackets
Speedbleeders
AVO Anti-Tramp rear differential bushing inserts
18" x 9.5" Enkei RS05RR in Matte Gunmetallic
265/35/18 Michelin Pilot Super Sport
Kics Iconix black lugnuts
Ichiba hubcentric spacers 10mm with extended studs (front)
5mm hubcentric spacer (rear)
H&R Trak 30mm Spacer (Front)
Blox 60mm Spacer (rear)
Air Lift performance Front struts
Air Lift performance Rear struts
Airt Lift Autopilot V2 air managment
Accuair 5gal air tank (powdercoated gunmetal grey)
Custom DOT approved PTC 1/4" air fittings (bulkhead)
Engine and Drivetrain
Perrin Light Weight Water pump and Alternator Pulleys
Perrin Master Cylinder Brace
Whiteline Transmission bushings
MTEC Shifter Springs
Kartboy Short shifter + Bushings
ECUTEK Cable + License
AVO Stage 1 Turbo Kit
AVO 50/50 Blowoff Valve
AVO Crossover Pipe (Ceramic Coated)
GrimmSpeed hood struts
GrimmSpeed exhaust gaskets
AEM Boost/AFR Failsafe Gauge
Innovate MTX-L Oil Pressure/Temp Gauge
Block8Head Custom defrost vent gauge mount
ATI Vent Pod gauge mount
Blitz EU GT86 specific Oil Sandwich plate with spacer
Grimmspeed black engine cover
Vibrant T-Bolt Clamps
Vibrant Vacuum Manifold
Vibrant Hose Clamps
Spencer Fabrication custom vent hard lines
Treadstone turbo blanket
ProSport remote oil pressure line
Custom dual catch can setup made by Saikou Michi
Perrin 3" Catback Exhaust
AVO 3" Downpipe
AVO 3" Ceramic Coated Overpipe
AVO 3" Ceramic Coated Front Pipe (no cat)
Perrin Cold Air Intake in Black
Delicious Tuning ECBS
Delicious Tuning Speed Density Tune (4 maps)
Target Based Boost Control
Full Blown Motorsports Oil Cooler
Exedy Stage 1 Clutch and Flywheel
Full Blown Fuel Pump setup with Warlboro 485
DW 450cc Port Injectors
Omni 3 Bar Map sensor
Gates Racing V-Belt
Full Blown Motorsports Aluminum Radiator
Full Blown Motorsports Aluminum rad shroud
Dual SPAL rad fans
Chase Bays coolant overflow tank
AVO upgraded 8 PSI actuator
P-Tuning Water/Meth Injection Kit with lightweight battery mount
Odyssey PC680 Battery
Fragola Oil Cooler Lines
Spencer Fabrication throttle body spacer and WMI injection plate
Cusco Liquid-to-Liquid oil cooler
STI Engine Mounts
Cusco Air/Oil separator
IAG billet aluminum master cylinder Cap
IAG billet aluminum clutch reservoir cap
IAG billet aluminum complete dipstick replacement
IAG billet aluminum washer fluid reservoir cap
Prova aluminum oil cap
Apexi coolant cap
Raceseng aluminum oil filter cover
APR Carbon Fiber cooling plate
GReddy Profec II Electronic Boost Controller
Interior, Audio, and Aero
LED Conversion for all bulbs in the car (plate, interior, trunk)
Amber LED front signal indicators
35% Tint
Toms JDM red tail lights
Hella Supertones
Perrin aluminum shorty antenna
Grimmspeed front license plate bracket
STi JDM rear wing gurney flap
STi JDM Push Button Start
Alpine PDXF4
JL C3 650 Speakers (front)
JL C2 350 Speakers (dash)
JL C3 650 Speakers (rear)
JL 10" WS3 Subwoofer
JL sealed subwoofer enclosure
Dynamat Extreme
Weathertech All Season Mats
Backup Camera
Debadged rear
Cusco aluminum E-Brake knob
Eur Toyota OEM arm rest
Aus Toyota OEM Black interior conversion
Rexspeed convex and polarized rear mirrors
Subaru Autodimming Homelink Mirror
Cipher Harness Bar
Takata Drift III Harnesses in Black (driver and passenger)
CaFi Dashlinq4 Toyota Universal headunit
DAMD Carbon Fiber core steering wheel
Prova shift knob
Custom hand made carbon fibre 3rd brake light relocation
Password:JDM Carbon Fibre 3 Piece front splitter
Password:JDM Carbon Fibre Side Skirts
Aero Jacket 1 piece carbon fibre trunk lid with duckbill spoiler
Driver and passenger Bride RO BRZ specific rails
Edirb 023 red stitch seats (driver and passenger)
Seibon carbon fibre hood type DV
Diode dynamics 6k HID headlight bulbs
Move Over Racing front bumper quick release kit
Longacre black adonized splitter support rods
Valenti smoked side markers
JDM Subaru Fog light housings (DRL Deletes)
Prova fender vents
OLM Vision+ DRL LED fog light housings and LED foglights
KMO Activities Todoroki front 30mm fenders (being painted)
GReddy Rocket Bunny V2 side skirts (on order)
GReddy Rocket Bunny V2 rear over fenders (on order)
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 09-15-2015, 07:21 PM   #2
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
voted.
ShibaYuki is offline   Reply With Quote
The Following User Says Thank You to ShibaYuki For This Useful Post:
protpibe (09-15-2015)
Old 09-15-2015, 08:20 PM   #3
Bergen23
Drives: '15 Halo FR-S
Normally, I don't vote in this stuff, but I'm so fucking jealous of your plate, that you get my vote.
Bergen23 is offline   Reply With Quote
The Following 2 Users Say Thank You to Bergen23 For This Useful Post:
drewbot (09-15-2015), protpibe (09-15-2015)
Old 09-15-2015, 08:26 PM   #4
protpibe
protpibe's Avatar
lol thanks, I appreciate it.
You mean my jets license plate??
Old 09-15-2015, 08:28 PM   #5
Bergen23
Yes, it's a hard life for a Jets fan when your dad is a die hard Leafs fan and you live within an hour of Toronto.
Old 09-15-2015, 11:25 PM   #6
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Wow the Jets plate looks way better/cooler than the usual Leafs plate
-Leafs fan
drewbot is offline   Reply With Quote
Old 09-16-2015, 12:12 PM   #7
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
I started reading the mod list, then I scrolled all the way down saw how long it was and gave up. in all seriousness really nice car, I'll vote for it when I get home tonight. Just for shits and giggles how much have you put total in that car?
fumanchu1 is offline   Reply With Quote
Old 09-16-2015, 01:43 PM   #8
protpibe
protpibe's Avatar
Although I know the number, I'll just leave it as "north of $50k" for parts lol. It's a little embarrassing but cars have always been a passion and hobby You should see my Toyota Echo ice racer lol
Votes are open to everyone again today (they are reset daily). I'm currently 8 votes back of the guy ahead of me, so I would appreciate if you guys took a minute to vote here:
Old 09-16-2015, 01:46 PM   #9
protpibe
protpibe's Avatar
Old 09-16-2015, 01:49 PM   #10
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
I wish I could vote for you, car's amazing but I don't have a Facebook.
The Following User Says Thank You to ZOMFGAARON For This Useful Post:
protpibe (09-16-2015)
Old 09-16-2015, 02:27 PM   #11
YangerD
YangerD's Avatar
Drives: 2017 Toyota 86
Voted, car is beautiful my friend! Wish I had "north of 50K" to spend on the car lol
YangerD is offline   Reply With Quote
The Following User Says Thank You to YangerD For This Useful Post:
Old 09-16-2015, 03:13 PM   #12
D_Thissen
D_Thissen's Avatar
Beautiful car sir! Voted!
The Following User Says Thank You to D_Thissen For This Useful Post:
Old 09-16-2015, 07:52 PM   #13
KPDoubleX
❤ fr-s love ❤
KPDoubleX's Avatar
Drives: 13 Asphalt Scion FRS
So impressed by this none widebody build, always have appreciatation for non-widebody, really well done cars.... then saw the additions on the bottom of the list....
Good luck, voted and I will hopefully see you at SEMA!
Asphalt Scion FR-S
Enkei | Aero Jacket | BC Racing | Invida | AFE | JL Audio | Seibon | Chargespeed | Cusco | Mishimoto | Spec D |
www.themodmarket.com
KPDoubleX is offline   Reply With Quote
Old 09-16-2015, 08:02 PM   #14
protpibe
protpibe's Avatar
Lol it's a decision I struggled with for a long time. I had to get wider fenders to
Fit my tire setup with air bags so I got todorokis. Although they look good, the back Looks disproportionately narrow so I went rb v2 sides. I'll be getting them moulded on to clean up the "rivet look" if need be
cant send private messages Lithium Site Announcements / Questions / Issues 0 03-21-2015 06:07 PM
Need a favor from a Canadian BRZ owner, (Canadian Base model with Manual Trans)) boomslang CANADA 1 09-07-2014 11:24 PM
Will someone please send me a datalog? ATSAaron Forced Induction 48 09-10-2013 10:29 PM
I can't send and receive PMs Hanakuso Site Announcements / Questions / Issues 1 06-14-2012 02:08 PM
TO ALL MY CANADIAN FRIENDS - BRZ Canadian Pricing Released zex BRZ First-Gen (2012+) — General Topics 7 04-24-2012 12:46 AM
