Drives: None
Springs for a modest 1-1.5 inch drop?
I am in the marker for a 1-1.5 drop set up without braking the bank. I also want to keep a soft set up. Maybe even softer than stock if possible. Would springs do the job? Or would it be best that I buy coilovers.
Need them comfortable enough for street use but also for a couple of track days a year. Any recommendation and info would be appreciated. Thanks |
Time Traveller
-1.0" is modest for springs. Eibach Pro-Kit or TRD Springs will get you there, but might be stiffer than what you're looking for. Remember, when you drop on springs alone the rate generally has to be stiffer (not softer) than stock.
-1.5", you'll need coilovers for a comfortable ride that you can also track every now and then. ST Coilovers are the way to go. You could also go with Tein Flex Z, which might handle better on the track, but will be sprung more stiff. I wouldn't go for a big drop (-1.4" or more) with springs (like Eibach Sportlines) as both the handling and ride will be compromised. |
| The Following User Says Thank You to DAEMANO For This Useful Post: | Astroboy (09-11-2015) |
Drives: 2014 BRZ
I'd like to add Swift Springs to the -1.0" choices!
| The Following 2 Users Say Thank You to jc0522 For This Useful Post: | Astroboy (09-11-2015), Hyper4mance2k (09-12-2015) |
Tein S Techs 110% of the way. I loved them and how especially how they rode.
| The Following 2 Users Say Thank You to megamarines For This Useful Post: | Astroboy (09-11-2015), MisterSheep (09-11-2015) |
Our RCE Yellow springs lower 20mm front and rear and include replacement bumpstops. Definitely mild.
1.5 inches is a lot for a spring and you make compromises going that low. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Astroboy (09-11-2015) |
Killed Scion
Drives: 2013 FR-S Whiteout
^^^^ go tein s techs. I just picked some up for $100 used off of some guy.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
| The Following 2 Users Say Thank You to MisterSheep For This Useful Post: | Astroboy (09-11-2015), megamarines (09-11-2015) |
Killed Scion
| The Following 2 Users Say Thank You to MisterSheep For This Useful Post: | Astroboy (09-12-2015), megamarines (09-11-2015) |
Drives: FRS
hotchkis springs are also AWESOME for the price and upgrade.
#10 |
+1 for RCE yellows. I have seen a lot of good reviews about them.
#11 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
90% of all aftermarket springs meet the thread title
Sent from my A0001 using Tapatalk |
#12 | |
Killed Scion
If you want to spend some more money get some Tein Street Basis. More adjustablilty than springs.
#13 |
Time Traveller
True that a lot of springs meet the thread title, but almost none meet the OP's acutual post requirements. "Softer than stock" and -1.0 - 1.5" drop. That's where he's probably going to have to make a compromise or spend more for coilovers.
Examples mentioned in the thread Stiffer than stock and less than 1.0" drop RCE Yellows (.8" drop) Stiffer than stock with 1.0" drop Eibach Pro Kit TRD Springs Swift Springs 86 kit Hotchkiss Springs 86 kit Tein H-Tech Stiffer than stock with 1.4" drop Eibach Sportlines Tein S-Tech Softer than stock and less than 1.0" drop RS-R Down Sus (.5" drop) Softer than stock (front only) with -1.2" drop but no replacement bump stops RS-R Superdown Sus The answer really is to save for coils. |
#14 | |
Drives: None
Where can I buy Trd springs. I see some on ebay, but don't know if legit Sent from my iPad using Tapatalk Last edited by Astroboy; 09-12-2015 at 06:56 PM. |
| ‡‡‡‡‡ Eibach SportLine Springs - IN STOCK - 1.4 inch drop! Plus package deals! ‡‡‡‡‡ | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 174 | 12-17-2014 02:41 AM |
| LCA for a 2 inch drop? | Estey | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 11-30-2014 10:38 AM |
| Alignment after 1 inch drop? | ang31ito | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-09-2014 12:20 PM |
| Half Inch Drop? | Ray_32 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 08-28-2013 06:44 PM |
| Picture of a FRS/BRZ with 18 inch+ wheels, no drop | forzajuve | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 05-18-2013 06:22 PM |
