That Guy
Drives: 2013 asphalt FRS MT
Thinking of adding spacers for looks, how much will it hurt handling?
Hey guys, as much as it pains me, I'm considering adding 15-20mm spacers to my wheels. I'm typically a function over form kind of person but with -2.5 camber in the front, -1.5 in the rear, and at 20mm lower than stock ride height, the look is getting to me.
Obviously I could get a wider rim/tire package, but that's too much money for me to spend on appearance. I like the stock rims just fine, they're light (relatively), and with MPSS's I don't feel any need for more grip. So, if I were to add spacers, how much would it mess up handling? Will I notice the scrub radius change? Will I lose steering feel? Thanks for the help. |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
There was a thread that turned to a turd about negative effects of scrub radius changes. Good luck, I am also interested in this topic.
Sent from my A0001 using Tapatalk |
You've already shifted the "dave point" outwards with the added camber, how much will depend on where the camber was added (knuckle or upper mount). Adding a spacer might actually bring it closer to stock.
That Guy
I added the camber at the knuckle. How does that change things?
Without a diagram it's kinda hard to explain, but just think about what defines the scrub radius, then look at how the angles were changed and what that does to the scrub radius.
Increasing SAI (adding camber at the upper mount) will move the scrub radius in the negative (outward) direction, adding camber at the knuckle will move it in the positive (inward) direction. My last post was wrong about all camber moving the pivot point outwards, forgot what the knuckle alignment looked like when I typed it.
#6 | |
I posted this in the other thread. I'd say +35mm offset is about the limit and ideally +40. But there's some wiggle room.
That Guy
#8 | |
(and it was fine at +38)But yes a 10mm spacer on the stock wheels is definitely OK. - Andrew |
| Spacers & Handling Performance | iLaw | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 08-27-2017 12:33 PM |
| Tein Street Basis Coilovers, will it hurt handling? | HGaudio | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 02-27-2015 02:28 PM |
| I hurt my FRS. | Zelica | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 07-19-2014 07:48 PM |
| Thinking of spacers, thoughts! | yomny | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 11-18-2012 10:43 PM |
| How do I know if I hurt my car??" | hislargeness | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 09-11-2012 06:33 PM |
