Old 02-25-2015, 08:25 PM   #1
HGaudio
Drives: 13' Scion FRS
Tein Street Basis Coilovers, will it hurt handling?
Hi I recently just purchased and 13' frs and I was doing some research on Coilovers for my car. Anyway I assumed that all Coilovers that were half decent would improve the handling with stiffer spring rates. I saw a post on here that members were saying unless you get at least 1500$ Coilovers it would hurt your cars handling. Would these Coilovers still allow me to lower my car and not hurt my handling noticeably? The reason I didn't want to go springs instead was because I wanted to drop my car a little more than 1.4 inches. Any input or advice would be greatly appreciated, thankyou!
HGaudio is offline   Reply With Quote
Old 02-26-2015, 08:45 AM   #2
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
I have Street Advance and I can't go below stock heights without too much loose in the coils which cause strong noises on big bumps...
The heights claimed by Tein seem very far from reality...
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 02-26-2015, 12:55 PM   #3
wparsons
wparsons's Avatar
How much under 1.5" do you want it? Lowering much beyond that will make it handle worse because of geometry issues regardless of how good the coilovers are.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
cdrazic93 (02-26-2015)
Old 02-26-2015, 06:34 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
that^
as soon as you get past some calculated height, no spring and damper combo regardless of manufacturer will make the car handle better. There is such a thing as too low, in terms of performance that is.
Old 02-26-2015, 07:00 PM   #5
8R6
8R6's Avatar
Drives: FRS
nope.
and $1500+ coilovers can still easily end up with "worse" handling than stock.
in my opinion, it doesn't matter even if someone gets $5k JRZ coilovers, if they don't know what/why/how they're modifying their suspension, a competent driver in a bone stock FRS can out-handle them with no problem.
8R6 is offline   Reply With Quote
The Following 3 Users Say Thank You to 8R6 For This Useful Post:
Astroboy (09-12-2015), Captain Snooze (02-27-2015), Teseo (12-29-2025)
Old 02-26-2015, 07:17 PM   #6
Racecomp Engineering
Originally Posted by cdrazic93 View Post
that^
I mean you can...but it takes pretty high spring rates which require really good dampers which cost a bunch of money plus you should get at least some form of roll center correction.
- Andy
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
CSG Mike (02-27-2015), wparsons (02-26-2015)
Old 02-26-2015, 07:50 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
- Andy
Its the roll center correction that helps immensely with the much lower geometry as the suspension model thread has acutely pointed out . Ofcourse different suspension styles can go lower. Typically you don't see a McPherson Strut going as low as a multi-link style on F1 while performing as well.
Old 02-26-2015, 08:00 PM   #8
Don't ever use the F1 comparison! It's just wrong.
With a strut the issues are travel and geometry.
- Andy
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Captain Snooze (02-27-2015), cdrazic93 (02-26-2015), wparsons (02-26-2015)
Old 02-26-2015, 08:35 PM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Merely using the extreme of extreme from the spectrum lol.
Old 02-26-2015, 09:01 PM   #10
HGaudio
Thanks for the advice and info guys. Well in your opinion do you think I'd be better off to go with the eibach springs and only drop it 1.4"?
Old 02-26-2015, 09:44 PM   #11
wparsons
wparsons's Avatar
You only have about 2.5" of bump travel at stock ride height, so dropping it 1.4" gives up more than you want for good handling.
If you want it that low, it's either going to cost you a lot or you're going to compromise handling.
flickr
Old 02-26-2015, 09:57 PM   #12
HGaudio
What does lowering your car do to hurt the handling? I'm curious to know what causes that
Old 02-27-2015, 03:31 AM   #13
banane63
banane63's Avatar
StreetBasis doesn't allow a big range of height because height is directly linked to coil preload, you should use StreetFlex instead.
Old 02-27-2015, 03:41 AM   #14
chas3wba0
chas3wba0's Avatar
Drives: Yes
Do you ever intend to drive your car fast on anything other than a smooth, well-paved road? Lowering will reduce the distance that your suspension is allowed to compress, and thus hinder it's ability to soak up obstacles and uneven surfaces, especially while cornering.
You'll also save a lot of headaches regarding bottoming out, scraping, etc. by not lowering. It's quite a commitment.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Tein Street Basis Coilovers installed jammz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 11-23-2018 08:20 AM
Installed Tein street basis coilovers!!!! Teeeg28 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 10-04-2014 01:03 PM
Tein Street Basis Coilovers? cncnjn Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-30-2013 01:52 PM
Tein H-Tech & S-Tech / Street Basis Coilovers & More / Great Deals @ Import DPS!! rickspecd Brakes, Suspension, Chassis 4 07-12-2013 11:49 AM
TEIN Street Basis Coilovers for BRZ/FR-S at Redline360 Redline360 Brakes, Suspension, Chassis 2 07-05-2012 08:36 AM
