Old 09-05-2015, 08:34 AM   #1
bRZillian7
Drives: 2015 Subaru BRZ Limited
Oft disappointment
So I have a 15 brz limited 6mt. I picked up an oft and flashed the appropriate stage one ROM for my calibration #. My car is basically stock aside from a k&n drop in. I have waited 5 days before posting here. I cannot tell any difference from the stock tune. I wanted to ask you guys if there's a considerable difference with a stock car.
Thanks in advance...
bRZillian7 is offline   Reply With Quote
Old 09-05-2015, 08:38 AM   #2
steve99
what octane fuel are you using ?
what is your rom calid like ZA1JD00C
can you log tune with oft and post log with knock parameters
IAM
FLKC
Knock Correction
AFR
maybe ring or email the openflash guys
Old 09-05-2015, 09:13 AM   #3
bRZillian7
Running 93 my calid is ZA1JD00c. I'm not sure how to log tune but I'll try it when I get home from work today.
IAM
FLKC
Knock Correction
AFR
Old 09-05-2015, 11:48 AM   #4
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
Do a 20 roll up to 60-70 from 2nd gear, then a 65-70mph pull up to about 80-85 in 5th and 6th. Revert to stock tune and repeat. See if you notice it then. When I first did mine I felt the same, didn't notice hardly any change. After going back to the stock tune it made me appreciate the OFT tune a lot more.
cameronjones239 is offline   Reply With Quote
Old 09-05-2015, 12:16 PM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
It's not a world of difference, but subtle. It also opens the door for bigger changes. Not sure what you were expecting, but the suggestion of doing some runs and then going stock is good, if you want to feel the difference. Though I've always found it takes a few drives for things to settle, out something like that.
Old 09-05-2015, 12:21 PM   #6
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
The main change is the torque dip between 3500-4500 is lessened. Just a tune does help, but you'll notice a large change when adding a header or E85
Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following User Says Thank You to Aztec For This Useful Post:
golfyankee2121 (09-06-2015)
Old 09-05-2015, 01:21 PM   #7
icybrzzz
Drives: 2015 Scion frz
I bought oft for my 2015 brz not expecting much of a difference. When I first flashed it I ran the 91 octane stage 1 tune. Drove around for a few days like that, and then threw on the 93 octane stage 1 EL tune. I could definitely feel the difference over the stock tune just daily driving. Feel more power down low and the throttle response is better. After driving for a few days with the 93 tune I switched back to stock tune and that's when I realized how much the car is improved with oft.
You sure you loaded the EL stage 1 tune?
icybrzzz is offline   Reply With Quote
Old 09-05-2015, 04:04 PM   #8
bRZillian7
EL as in Equal Length Header? I have stock the header in
Old 09-05-2015, 04:26 PM   #9
cameronjones239
Yes you should load the EL - equal length header stage 1 tune for a stock brz/frs
Old 09-05-2015, 05:11 PM   #10
Yoda
Drives: Crystal Black BRZ(Sophia)
umm not so sure about that.
Yoda is offline   Reply With Quote
Old 09-05-2015, 05:28 PM   #11
icybrzzz
From what I've researched thats the tune that was recommended to run on a stock brz/frs.
Maybe someone with more knowledge on this could chime in? It has worked for me and the car feels great with this tune.
Old 09-05-2015, 05:46 PM   #12
Weapon86
Weapon86's Avatar
Drives: 2014 Scion FRS monogram series
Do you have a manual or auto transmission?
Weapon86 is offline   Reply With Quote
Old 09-05-2015, 05:55 PM   #13
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Oft disappointment
You are just expecting a bit much I guess.
Oft does a bit more if u have a header. But it's still an offshelf tune, don't expect too much. You would get more from a proper tune/header/e85.
Old 09-05-2015, 06:26 PM   #14
Chad11491
Drives: 85.5 Porsche 944, '15 mustang GT PP
I'm very pleased with mine with a jdl uel. I think I will eventually go the ecutek/flex fuel route though long term.
Chad11491 is offline   Reply With Quote
Valenti Tail lights disappointment/question kincito Cosmetic Modification (Interior/Exterior/Lighting) 27 07-02-2014 09:47 PM
Pre-Order Disappointment woes Draco233 BRZ First-Gen (2012+) — General Topics 16 03-03-2012 04:31 PM
BRZ pricing disappointment thread dsgerbc BRZ First-Gen (2012+) — General Topics 42 02-29-2012 02:37 PM
