Old 09-04-2015, 09:50 PM   #1
CyberAkuma
OOH KILL EM
CyberAkuma's Avatar
Drives: FG1 Civic,NA Miata, Whiteout FRS MT
Front tire losing air
Hey everyone, I have aftermarket wheels and tires on but the front tire seems to lose air and I have to check up on it weekly. What could be the cause of this? Is it the tire itself or could it be a leaking air from the valve stem?
Instagram: 8as6
CyberAkuma is offline   Reply With Quote
Old 09-04-2015, 10:16 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Either of those or a bad seal at the wheel...
Old 09-04-2015, 10:17 PM   #3
swarb
Most likely something in the tire or valve stem.
Possible but unlikely, 3 piece wheels not sealed fully, or the bead tire not sealing with the rim.
Old 09-04-2015, 10:20 PM   #4
CyberAkuma
OOH KILL EM
CyberAkuma's Avatar
My wheels are indeed 3 piece, who or where do you recommend I take my wheels to for a check up? Thanks for the response
Instagram: 8as6
Old 09-04-2015, 10:27 PM   #5
swarb
www.vrwheels.com
Check tire/valve stem first.
What wheels and size? Are they new? Have they been taken apart?
What tires and size? Are they new?
Are the valve stems new? metal or rubber?
Stretched tires can leak air due to bead not sitting flat on the rim.
Old 09-04-2015, 10:34 PM   #6
EzyBrzy
Drives: 2015 WRB BRZ
Take it to a local tire shop.
EzyBrzy is offline   Reply With Quote
Old 09-04-2015, 10:52 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
Dunk wheel/tire in water
Watch for bubbles
Spraying on a soapy mix will also produce bubbles if you don't want to take your wheel swimming
2013 FRS
Vortech V3 11psi
Old 09-04-2015, 11:10 PM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
My money is on valve steams. Like others said just take it on to any tire shop. Unless you have some crazy hellastreach set up, then it could be something else.
air, random, valve stem
losing traction? sskillzz12 Engine, Exhaust, Transmission 4 03-24-2015 09:51 PM
Losing control Derickie Scion FR-S / Toyota 86 GT86 General Forum 76 05-30-2014 03:25 AM
Losing Coolent nabil_frs Issues | Warranty | Recalls / TSB 10 09-06-2013 12:25 AM
Been on a losing streak with my car lately...help sa1126 Scion FR-S / Toyota 86 GT86 General Forum 5 04-01-2013 10:18 PM
I'm losing it. How did you cope? Kyubi Scion FR-S / Toyota 86 GT86 General Forum 56 01-09-2013 02:20 AM
