Old 09-03-2015, 02:13 PM   #1
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Question FI people what typ of oil do you use for your engine to compensate for higher temps
Sorry if anything like this exist but I can only find NA oil threads.
As title states, I am wondering what type/brand and weight oil you are using and with which setup SC or turbo and what kit parts.
Reason for this is I have a KW c38 supercharged 2013 brz and am wondering for what type of oil I should switch if any.
I would love any analysis you guys would have had done also to help illustrate the oil's performance and type of driving you typically do. (Also I'm from Canada and will drive the car in winter too but would like to stay away from liquid gold if possible)
From what I know right now a good choice for my next oil would be 5w30(lots of FI seem to be running that grade or 0w30 of oil with good results for DD cars and light track use).
Don't need a flame war but any recommendations, advice, help or what to stay away from would be greatly appreciated.
fumanchu1 is offline   Reply With Quote
Old 09-03-2015, 03:52 PM   #2
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
0W20 MOBIL 1
freeway driving 25+ miles
and back canyon roads
i <3 Boost
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 09-03-2015, 09:13 PM   #3
viscositosis.rex
Drives: Currently 2018 Taco
Originally Posted by BRZtoni View Post
0W20 MOBIL 1
i <3 Boost
What color is the cap on your bottles of Mobil 1?
viscositosis.rex is offline   Reply With Quote
Old 09-03-2015, 09:16 PM   #4
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
GREEN
Flex Fuel Turbo BRZ
Old 09-03-2015, 10:39 PM   #5
viscositosis.rex
GREEN
Ah. AFE. HTHS 2.61.
Gold cap is EP. More esters. HTHS 2.7 (slightly thicker)
Good call.
FWIW I prefer GREEN.
Canyons.
Topanga?
OC?
CA climate is so mild.
Freeway miles a plus.
Out.
where's bluesubie?
Old 09-04-2015, 11:31 AM   #6
fumanchu1
The sheer number of responses is staggering...*cough* *cough*.
Old 09-04-2015, 07:00 PM   #7
stevo585
Drives: White 2014 BRZ
You need an oil cooler and then just run 0w-20.
stevo585 is offline   Reply With Quote
Old 09-04-2015, 08:46 PM   #8
protpibe
protpibe's Avatar
I run amsoil signature 0w30 with an AVO setup that maxes at 15psi
Old 09-08-2015, 12:32 AM   #9
Crazypinoy9
Drives: FR-S TRD RS1#1488
mobil 1 0w40 and I've got an oil cooler with a thermostatic plate
Crazypinoy9 is offline   Reply With Quote
Old 09-08-2015, 10:06 AM   #10
You compensate for higher oil temps by getting an oil cooler.
Supercharging your engine doesn't change your engine's oil weight spec.
BrahmaBull1990 (07-28-2021), Chad86 (09-12-2015)
Old 09-08-2015, 12:08 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
and you start using heavier weight oil if desired pressure isn't achieved.
-alex
Old 09-08-2015, 04:27 PM   #12
bluesubie
Originally Posted by viscositosis.rex View Post
Ah. AFE. HTHS 2.61.
Good call.
Canyons.
Topanga?
OC?
Out.
where's bluesubie?
IMO, HTHS should be listed on the bottle instead of a viscosity range. Even between oils with the same numbers on the bottle (eg. 0W-30), you can have different film strength and oil pressure.
0W-30 isn't saying much, but a 0W-30 with a low HTHS like Mobil1 (HTHS 3.0) compared to a Euro 0W-30 like Euro Castrol 0W-30 with an HTHS of at least 3.5 will have the Castrol behaving more like a 40 grade.
bluesubie is offline   Reply With Quote
Old 09-09-2015, 08:20 PM   #13
viscositosis.rex
Agreed. There should be precise, accurate, detailed information on the table for us consumers to make choices on.
I often ask myself what I would do if facing the types of dilemmas you guys do. At this point, I believe it would involve frequent oil changes, with a motor oil I had confidence in, but was economical in price.
It was surprising to read today, a link to an article, posted by an expert in the field, where he referred to a "Group III+" motor oil.
As someone who is big on base stocks, I would be interested in your thoughts, Dennis, on using Pennzoil Platinum Euro (GTL) vs using Motul (Group IV).
Do FT86 trackers really, really prefer esters?
Old 09-09-2015, 08:43 PM   #14
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I know in japan the racing oils for 86/brz is 5W-40 (actually STI racing Oil for BRZ is 5w-40 as well)....obviously not normal offshelf ones & cost a lot more. O.O... like this picture below.
Air temps and impact on engine load brn12345 Software Tuning 0 04-30-2014 02:50 PM
Boxer engine and temps SlinkyAvalanche Engine, Exhaust, Transmission 9 03-27-2014 03:00 PM
Looking for a Subaru BRZ in WRB Color for color-match. Will Compensate Roof Spoiler Beat-Sonic Southern California 19 03-09-2014 07:31 PM
Reducing engine compartment temps mike_ekim1024 Engine, Exhaust, Transmission 1 12-11-2013 02:57 AM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
