| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2013 Brz C38 (bought not built :P)
Sorry if anything like this exist but I can only find NA oil threads.
As title states, I am wondering what type/brand and weight oil you are using and with which setup SC or turbo and what kit parts. Reason for this is I have a KW c38 supercharged 2013 brz and am wondering for what type of oil I should switch if any. I would love any analysis you guys would have had done also to help illustrate the oil's performance and type of driving you typically do. (Also I'm from Canada and will drive the car in winter too but would like to stay away from liquid gold if possible) From what I know right now a good choice for my next oil would be 5w30(lots of FI seem to be running that grade or 0w30 of oil with good results for DD cars and light track use). Don't need a flame war but any recommendations, advice, help or what to stay away from would be greatly appreciated.
#2 |
Turbo E85
Drives: 13 wrb brz
0W20 MOBIL 1
freeway driving 25+ miles and back canyon roads i <3 Boost
Flex Fuel Turbo BRZ
#3 |
Drives: Currently 2018 Taco
#4 |
Turbo E85
Drives: 13 wrb brz
GREEN
Flex Fuel Turbo BRZ
#5 |
#6 |
The sheer number of responses is staggering...*cough* *cough*.
#7 |
Drives: White 2014 BRZ
You need an oil cooler and then just run 0w-20.
#8 |
Drives: 4-Runner Sport - 13' BRZ SportTech
I run amsoil signature 0w30 with an AVO setup that maxes at 15psi
Top Tier Imports - Check out my build journal HERE
#9 |
Drives: FR-S TRD RS1#1488
mobil 1 0w40 and I've got an oil cooler with a thermostatic plate
#10 |
You compensate for higher oil temps by getting an oil cooler.
Supercharging your engine doesn't change your engine's oil weight spec. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | BrahmaBull1990 (07-28-2021), Chad86 (09-12-2015) |
#11 |
Drives: 2005 Toyota Camry
#12 | |
Drives: 2004 Subaru Forester 2.5XT
0W-30 isn't saying much, but a 0W-30 with a low HTHS like Mobil1 (HTHS 3.0) compared to a Euro 0W-30 like Euro Castrol 0W-30 with an HTHS of at least 3.5 will have the Castrol behaving more like a 40 grade. |
#13 | |
I often ask myself what I would do if facing the types of dilemmas you guys do. At this point, I believe it would involve frequent oil changes, with a motor oil I had confidence in, but was economical in price. It was surprising to read today, a link to an article, posted by an expert in the field, where he referred to a "Group III+" motor oil. As someone who is big on base stocks, I would be interested in your thoughts, Dennis, on using Pennzoil Platinum Euro (GTL) vs using Motul (Group IV). Do FT86 trackers really, really prefer esters? |
#14 |
The Fail Boat
Drives: CWP S.B.
I know in japan the racing oils for 86/brz is 5W-40 (actually STI racing Oil for BRZ is 5w-40 as well)....obviously not normal offshelf ones & cost a lot more. O.O... like this picture below.
| Air temps and impact on engine load | brn12345 | Software Tuning | 0 | 04-30-2014 02:50 PM |
| Boxer engine and temps | SlinkyAvalanche | Engine, Exhaust, Transmission | 9 | 03-27-2014 03:00 PM |
| Looking for a Subaru BRZ in WRB Color for color-match. Will Compensate Roof Spoiler | Beat-Sonic | Southern California | 19 | 03-09-2014 07:31 PM |
| Reducing engine compartment temps | mike_ekim1024 | Engine, Exhaust, Transmission | 1 | 12-11-2013 02:57 AM |
| Normal Engine Coolant Temps? | Dezoris | Engine, Exhaust, Transmission | 1 | 04-05-2013 03:17 PM |
