Drives: 2013 ultramarine Scion FR-S
Fidanza flywheel review
I've put in quite a few Fidanza flywheels over the years. I've had them in Civics, MR2s, and an AE86s.
They were all characterized by needing quite a bit of throttle to get going. The lack of rotational inertia was rather obvious. I just dropped a Fidanza in my FR-S with an Exedy OEM replacement clutch and Driveshaftshop aluminum driveshaft. I've been thus far surprised at the driving characteristics. The only time I notice the lack of rotational inertia is how quickly revs fall from high RPMs. Starting from a stop is not at all difficult. If you're considering a flywheel and are expecting the Fidanza to behave as it does on lower displacement or lower powered cars, it doesn't. I have noticed quite a bit more drivetrain noise below 2500 RPM. It sounds like lugging up to about 2200 RPM. Makes some sense, but it is a negative, as that's around-town RPMs. I think the one piece driveshaft probably contributes to that. Anyway. That's my thoughts. Please comment or ask any questions. Sent from my XT1045 using Tapatalk Last edited by burdickjp; 08-30-2015 at 07:21 PM. |
#2 | |
Drives: GT86
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits |
Resident Gear Head
Not sure if the flywheel is making the noise or that you have paired it to a Aluminum driveshaft at the same time which its a hollow resonating tube.
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
Drives: GT86
Mine is still on the stock drive shaft (well, we call it a prop shaft here in the UK) and I get the same horrible noise he's talking about when the engine is bogging down a little and I didn't notice that much before I got the new flywheel installed
Drives: '23 BRZ Limited
It's the transmission if it's a "rattle" sound. The lighter flywheel doesn't dampen the power pulses as much so you're hearing the clearance between the gears.
Not a big deal. |
#6 | |
Resident Gear Head
Many people complaining about upgraded clutch on stock flywheel making noises as well.
^"I put race car parts on my car, why aren't they as quite as OEM?"
I wouldn't describe it as horrible. It makes more noise. It's understandable.
Sent from my XT1045 using Tapatalk |
| Anyone tried a Fidanza Clutch and flywheel set | JesseE | Engine, Exhaust, Transmission | 19 | 08-29-2017 09:52 PM |
| Fidanza Qwik-Rev V2 Clutch | BRZFern | Engine, Exhaust, Transmission | 5 | 11-03-2014 06:15 PM |
| Fidanza Qwik Rev Clutch & Flywheel kit | MAPerformance | Transmission and Driveline | 10 | 01-03-2014 10:03 AM |
| Default BLACK FRIDAY BLOWOUTS - KW l BC Racing l Cobb l AVO l Fidanza + More! | Circuit Motorsports | Announcements, Contests, Giveaways | 0 | 11-29-2013 12:18 PM |
| ACT HD pressureplate, Prolite Flywheel and Performance Street Disc review | wu_dot_com | Engine, Exhaust, Transmission | 0 | 10-31-2012 06:40 PM |
