Old 08-30-2015, 06:29 PM   #1
burdickjp
Drives: 2013 ultramarine Scion FR-S
Fidanza flywheel review
I've put in quite a few Fidanza flywheels over the years. I've had them in Civics, MR2s, and an AE86s.
They were all characterized by needing quite a bit of throttle to get going. The lack of rotational inertia was rather obvious.
I just dropped a Fidanza in my FR-S with an Exedy OEM replacement clutch and Driveshaftshop aluminum driveshaft.
I've been thus far surprised at the driving characteristics. The only time I notice the lack of rotational inertia is how quickly revs fall from high RPMs. Starting from a stop is not at all difficult.
If you're considering a flywheel and are expecting the Fidanza to behave as it does on lower displacement or lower powered cars, it doesn't.
I have noticed quite a bit more drivetrain noise below 2500 RPM. It sounds like lugging up to about 2200 RPM. Makes some sense, but it is a negative, as that's around-town RPMs. I think the one piece driveshaft probably contributes to that.
Anyway. That's my thoughts. Please comment or ask any questions.
Sent from my XT1045 using Tapatalk
burdickjp is offline   Reply With Quote
Old 08-30-2015, 08:25 PM   #2
ChrisD
ChrisD's Avatar
Drives: GT86
I had a similar opinion after getting mine installed - didn't seem to make much noticeable difference to performance. I've also noticed a lot of noise under 2500 RPM as well. Tempted to swap back to the stock flywheel just to get rid of the horrible noise tbh
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
Old 08-31-2015, 10:02 AM   #3
celek
Resident Gear Head
celek's Avatar
Not sure if the flywheel is making the noise or that you have paired it to a Aluminum driveshaft at the same time which its a hollow resonating tube.
celek is offline   Reply With Quote
Old 08-31-2015, 10:45 AM   #4
ChrisD
ChrisD's Avatar
Drives: GT86
Mine is still on the stock drive shaft (well, we call it a prop shaft here in the UK) and I get the same horrible noise he's talking about when the engine is bogging down a little and I didn't notice that much before I got the new flywheel installed
Old 08-31-2015, 10:58 AM   #5
OkieSnuffBox
Drives: '23 BRZ Limited
It's the transmission if it's a "rattle" sound. The lighter flywheel doesn't dampen the power pulses as much so you're hearing the clearance between the gears.
Not a big deal.
Old 08-31-2015, 10:58 AM   #6
celek
Resident Gear Head
celek's Avatar
OE clutch or upgraded?
Many people complaining about upgraded clutch on stock flywheel making noises as well.
Old 08-31-2015, 11:00 AM   #7
OkieSnuffBox
^"I put race car parts on my car, why aren't they as quite as OEM?"
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
celek (08-31-2015)
Old 08-31-2015, 01:53 PM   #8
burdickjp
I wouldn't describe it as horrible. It makes more noise. It's understandable.
Anyone tried a Fidanza Clutch and flywheel set JesseE Engine, Exhaust, Transmission 19 08-29-2017 10:52 PM
Fidanza Qwik-Rev V2 Clutch BRZFern Engine, Exhaust, Transmission 5 11-03-2014 07:15 PM
Fidanza Qwik Rev Clutch & Flywheel kit MAPerformance Transmission and Driveline 10 01-03-2014 11:03 AM
Default BLACK FRIDAY BLOWOUTS - KW l BC Racing l Cobb l AVO l Fidanza + More! Circuit Motorsports Announcements, Contests, Giveaways 0 11-29-2013 01:18 PM
ACT HD pressureplate, Prolite Flywheel and Performance Street Disc review wu_dot_com Engine, Exhaust, Transmission 0 10-31-2012 07:40 PM
