Old 08-26-2015, 02:51 PM   #1
dmyers
dmyers's Avatar
Drives: Subaru BRZ 2013 Dark Gray
PA Emissions Questions
If your in a part of PA which has the emissions requirements I have a questions for ya. I assume we have enough members here that somebody in PA would know the answer?? so here goes.
If I go with the Afe Twisted Steel Headers w/Cat; Scion FR-S/Subaru BRZ 13-15 H4-2.0L 48-36005-HC (I didn't post a link because I'm not sure what the rules are on that?) which includes a CAT. From what I understand they only do a ODBII scan - which should?? pass because it would use the same sensor as stock and be located after the cat (like stock). Am I correct on this assumption? Do we have any other requirements? (visual? some needed sticker etc???)
Thank you in advance.
dmyers is offline   Reply With Quote
Old 08-27-2015, 08:44 PM   #2
Outlawstar98
SLOW BRZ
Outlawstar98's Avatar
Drives: 2013 328i xDrive; 2013 BRZ
Will pass.
Outlawstar98 is offline   Reply With Quote
Old 08-27-2015, 08:45 PM   #3
Outlawstar98
SLOW BRZ
Originally Posted by Outlawstar98 View Post
Will pass.
Also, I know west Chester.
Old 08-27-2015, 10:27 PM   #4
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
I'm originally from SouthEastern, PA. Some places will do a visual inspection for 2nd cat aka under the car, other than that, it's OBD2 scan. So even if you went catless, and had it tuned, you'd be good as long as you kept the catted front pipe
Rifle is offline   Reply With Quote
Old 09-01-2015, 10:02 AM   #5
Wepeel
Drives: '13 BRZ Ltd
Even though the header has a cat, it's not a guarantee that it won't throw a CEL. Aftermarket catted headers can and do still throw codes. If it doesn't throw the CEL, you will pass fine. If it does throw a CEL, you will not pass. If you run a tune that suppresses that CEL, you will pass.
Wepeel is offline   Reply With Quote
Questions about tuning and emissions for FI GREATNEESSS Forced Induction 11 07-24-2015 09:54 PM
Question on PA emissions Optimus Prime NY / NJ / CT / PA 8 05-22-2014 09:35 PM
Emissions - MD TheseColorsDontRun Mid-Atlantic 6 08-23-2013 06:06 PM
Question regarding emissions. Fourskim Northwest 7 06-30-2013 04:23 PM
California emissions questions bdanisi Engine, Exhaust, Transmission 34 04-26-2013 12:11 AM
