Old 06-24-2015, 10:02 PM   #1
GREATNEESSS
Questions about tuning and emissions for FI
Ok so I am looking to get an exhaust set up and I know I would need to swap back the stock parts to pass a smog. I will also be looking to get a s/c thats carb legal like vortech.
My first question is for the exhaust do i need to swap back everything aside from the cat back to pass emissions or just the header and the frontpipe since they have the stock cat?
Will the car be fine with the the s/c on the same tune with exhaust components swapped out?
Will the s/c need to be on the base tune to pass emissions or will it pass regardless of a custom tune?
I know first question is strictly exhaust related but I didn't want to have to post on to sections
Thanks any info would be appreciated greatly!
GREATNEESSS is offline   Reply With Quote
Old 06-24-2015, 10:13 PM   #2
kbogarto
Drives: 2013 BRZ limited WRB
If you get a CARB rated supercharger the tune is locked. If you get a custom tune it will not be CARB rated.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 06-24-2015, 10:34 PM   #3
GREATNEESSS
So then I could just go back to the original tune?
Old 06-24-2015, 10:43 PM   #4
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Yeah, so if you get the CARB tune and you change out your exhaust and let's say you go catless just swap the stock parts back on. Now if you get a tune from Delicious you can just put the stock parts back on and then reflash it to the CARB tune. And after you pass just reflash and reinstall your parts.
Alltezza is offline   Reply With Quote
The Following User Says Thank You to Alltezza For This Useful Post:
GREATNEESSS (06-24-2015)
Old 06-24-2015, 10:48 PM   #5
GREATNEESSS
thanks
that makes a lot of sense
Old 06-24-2015, 10:56 PM   #6
You need the stock header and front pipe to pass visual.
The custom tune may or may not pass the sniffer; there's only one way to find out and if you fail, your car will permanently be flagged.
You don't *need* to be on the CARB tune to pass, but technically you're supposed to be on it.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
#maverick# (06-25-2015), Dream20b (07-24-2015), GREATNEESSS (06-24-2015)
Old 06-24-2015, 11:11 PM   #7
GREATNEESSS
ya i just read on another forum post that they mainly check to see if your car throws back any codes. Im guessing i should be fine with just swapping back the header and front pipe. The tune would be just to be extra safe.
Old 06-25-2015, 03:10 AM   #8
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
if your car gets flagged what happens? Do they pay more attention to your car the next time around? Or a fine? Just curious... i had no idea cali laws were that strict.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 06-25-2015, 12:52 PM   #9
You have to get a STAR smog test every other year (sniffer), instead of just a visual and obd2 readyness
Old 06-25-2015, 12:54 PM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I would flash back to the CARB tune before going to get checked. It takes all of 5 minutes, why not
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
#maverick# (06-25-2015), CSG Mike (06-25-2015), RobertPaulson (07-24-2015)
Old 07-24-2015, 02:04 PM   #11
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
What if you installed a turbo kit with an aftermarket catless turbo manifold/header, but replaced the frontpipe with one of these catalytic converter replacements?
These dual cat pipes seem to simply relocate the first cat from the stock header to the front pipe. Obviously, your exhaust will still be more concentrated due to the forced induction, but wouldn't this keep the smog output at legal levels?
With a low boost tune, this type of setup seems like it would pass emissions testing in theory, although I'm not sure about the visual inspection. Can anyone comment? This seems to me like an easy way to pass emissions testing without having to swap out your header. The Magnaflow Cat claims to be OEM Grade for CARB emissions requirements outside the state of California.
I'm trying to install a turbo kit on my 6AT that will pass emissions with minimal effort since the Works CARB legal kit is only for MT. I live in CT which is a CARB state but I don't think they're as strict as CA.
avishenoy1 is offline   Reply With Quote
Old 07-24-2015, 09:54 PM   #12
Dream20b
Y u do dis?
you cannot legally (emissions wise) move your cats.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Ecutek tuning software questions for newbie keonigt Software Tuning 2 05-28-2015 03:59 AM
Trying to research about ECU tuning, a couple of questions Drakelee117 Software Tuning 29 03-10-2015 03:42 PM
Tuning questions and help KonTheory Software Tuning 26 06-24-2014 04:16 AM
Questions about EcuTek tuning. marine6680 Software Tuning 15 08-19-2013 10:07 AM
California emissions questions bdanisi Engine, Exhaust, Transmission 34 04-26-2013 12:11 AM
