Southern California SoCal
Old 08-25-2015, 07:53 PM   #1
Roneezy
Roneezy's Avatar
Drives: Scion FRS Halo White 2015
San Diego Lowering Springs Install
Hi, I was wondering if anyone knew a good place to get my Eibach Pro lowering springs installed. I can't really do it myself because I don't have the tools and I don't have friends who know how nor have tools as well lol.
I'm located in San Diego, if anyone knows a place or someone who's familiar with the twins that would be much appreciated.
Roneezy is offline   Reply With Quote
Old 08-26-2015, 10:05 AM   #2
DannyQ86
Drives: 2013 frs
You could always head down to harbor freight and it would probably cost you less than a 100 bucks for everything you need. Most of the cost would be the jack and stands. If your not too mechanically inclined there are a few DIY on here for lowering spring install. Just make sure you don't spin the shaft while loosening the top nut. Just use an Allen key to hold it in place while you loosen the nut. Sorry I'm in la county so I can't really help you. If you can't seem to find the link for the DIY pm me and I'll help you locate it. Good luck
DannyQ86 is offline   Reply With Quote
The Following User Says Thank You to DannyQ86 For This Useful Post:
Roneezy (08-26-2015)
Old 08-26-2015, 01:25 PM   #3
Roneezy
Roneezy's Avatar
Thanks a lot man, I'll look into that. If I'm not too retarded I'll most likely end up doing it myself lol.
Old 08-26-2015, 02:16 PM   #4
@Infamous Performance
Old 08-26-2015, 03:14 PM   #5
Roneezy
Roneezy's Avatar
Thanks for the info! I tried calling twice, but it seems like they're busy. I'll give them another call again when i receive my springs this Friday. If not I might go the DIY route.
Racecomp Engineering Yellow lowering springs install special! Racecomp Engineering Mid-Atlantic 12 12-17-2015 01:34 PM
TRD springs or DIY lowering? DigitalVeil92 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 10-01-2015 04:15 PM
help with lowering springs in NC tazz786 Southeast 2 03-08-2015 12:02 AM
Lowering Springs install help HATED1 Northwest 6 03-10-2013 03:47 PM
Looking for a place to install lowering springs in DFW area frs_firestorm Southwest 7 02-16-2013 12:55 AM
