Old 11-21-2012, 02:57 PM   #1
Racecomp Engineering
Racecomp Engineering Yellow lowering springs install special!
We're in the holiday spirit and would like to offer the Mid-Atlantic section a special install deal for our popular RCE Yellow springs for BRZ and FR-S!
RCE Yellow sport lowering springs
$CALL!
These are the best functional sport spring for your BRZ/FR-S. Spring rates and drop chosen to improve handling and maintain great ride quality. They just happen to look good.
We include replacement shortened bumpstops to maximize available bump travel.
Please contact us if you are interested or if you would like to inquire about any other installation deals!
* mods, i PMed Hachiroku for permission to post this here.
Old 11-21-2012, 02:58 PM   #2
A few more details on our RCE Yellow springs.
Spring rates:
250 lbs/in front and rear
Drop:
20mm drop front and rear.
Replacement bumpstops are INCLUDED. Rates are linear at normal ride height.
We've maintained a similar easily controlled balance of the OEM car with just a bit more aggressiveness. The car simply has less pitch, dive, and roll for an even more responsive chassis that is well balanced at the limit. These functional springs works very well on the OEM tires and with stickier rubber.
The 20mm drop was chosen to maximize function. Good suspension geometry and with the help of the replacement bumpstops, proper compression travel remains for the suspension to work instead of easily bottoming out...whether it's in a corner or broken pavement. Better ride quality, better handling, and more predictable all around.
AVO Turboworld's review:
Originally Posted by AVOturboworld View Post
Ok - improved bushings w/RCE Yellows will have you laughing like a ape through corners. Can't wait for that alignment shop to open up...
http://www.ft86club.com/forums/showt...915#post473915
Old 11-21-2012, 04:14 PM   #3
xjohnx
Grip>Slip
xjohnx's Avatar
I'm assuming there's no alignment included at that price?
Old 11-21-2012, 10:55 PM   #4
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
Extremely interested! How much extra would it cost to install/align the "BRZ Lite" kit with the Whiteline bushings and crash bolts? When is the shop available for install?
TyperRspec789 is offline   Reply With Quote
Old 11-23-2012, 08:57 AM   #5
itsfun
itsfun's Avatar
Drives: SWP BRZ Limited
Also interested in a special for an install/align of the Lite kit! Headed to Tokyo for work on Nov 28th and can drop the car off for the install. Holiday special price in exchange for hand carry of JDM parts? =D
itsfun is offline   Reply With Quote
Old 11-23-2012, 08:42 PM   #6
EJ33177
EJ33177's Avatar
Drives: 2013 Scion FRS Ashpahlt AT
Definitely some interest here!
EJ33177 is offline   Reply With Quote
Old 11-25-2012, 04:52 PM   #7
LIKEABOSS
LIKEABOSS's Avatar
Drives: 2013 Boss 302 & 2013 FR-S
I might be interest if alignment is included.
LIKEABOSS is offline   Reply With Quote
Old 11-29-2012, 12:11 PM   #8
Jatterbu
Drives: E28 M5, E39 M5
Any plans on you guys making the coilovers as well for these cars? Probably don't remember me but I worked for StopTech a while back when I was still in SoCal. I helped put some of your coils on my roommates STi, Erik Steinkamp, who also worked at StopTech. They were fantastic on and off the track.
Joey
Jatterbu is offline   Reply With Quote
Old 11-29-2012, 12:14 PM   #9
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
any plans to offer a different rear spring rate? As an FRS owner Id be interested in keeping the balance of my car more like OEM Toyota rather than OEM Subaru. There's no doubt you guys have probably the best lowering springs for this car.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 12-03-2012, 07:29 PM   #10
Hey guys, sorry for dropping out of this thread! I'll try to answer questions here more promptly.
The price listed does not include an alignment. We are not set up to perform alignments yet in our shop.
All driving testing was done on two BRZs, one preproduction model and our own car. We did test the OEM springs of the FRS and they are indeed different; however, the dampers are identical and that's what matters. With our springs on the cars will handle the same. We have done three or four installs on an FRS and the driving dynamics are exactly where we want them to be. And that means much better turn in, mid corner grip, and more control exiting corners. The stock dampers are pretty good so it gives us some room to work with.
We would usually offer up our own BRZ for test rides but right now it has our RCE T2 KW coil over prototypes. Maybe we can get a little meet going so people could try out a few different set-ups?
Please call to work out details if you're interested in the install special.
- andrew
Old 11-30-2015, 01:04 PM   #11
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Im looking for a set of lowering springs for my BRZ and it think this products fits my needs. Im looking to reduce the wheel gap while maintaining current handling and performance (or potentially improving it).
Jfheisenberg is offline   Reply With Quote
Old 12-17-2015, 01:10 PM   #12
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Just for the record, I don't know if RCE is still doing this promotion since the thread is three years old.
But basically ever since the Yellow springs have been out, I've had them on my car. They've been great. I bought Koni Sport (yellow) shocks at the same time, and I really like the combination.
Grimlock is offline   Reply With Quote
Old 12-17-2015, 01:34 PM   #13
Jfheisenberg
that looks very nice, lll be using the stock shocks though..
Racecomp Engineering BRZ build! Racecomp Engineering Member's Car Journals 83 07-14-2014 08:18 PM
BRZ lowered on RaceComp Engineering springs! OrbitalEllipses Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 03-19-2014 06:26 PM
Racecomp Engineering Yellow Springs and Cusco Lower Control Arm Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-28-2013 12:22 AM
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 08:12 PM
Racecomp Engineering coilover sales: JRZ RS1 and KW V3 Racecomp Engineering Brakes, Suspension, Chassis 29 09-17-2012 10:46 AM
