Old 08-22-2015, 02:41 AM   #1
troek
troek's Avatar
Drives: 2012 Toyota 86
Cusco Oil Cooler
SOLD
troek is offline
Old 08-25-2015, 05:42 PM   #2
troek
troek's Avatar
bump
troek is offline
Old 08-25-2015, 07:01 PM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Please follow the member classified rules or I'll delete the thread
thanks
ichi
ichitaka05 is offline
whataboutbob (08-25-2015)
Old 08-25-2015, 09:35 PM   #4
troek
troek's Avatar
gotcha, will be posting a pic with username, date, and site name soon.
troek is offline
Old 09-01-2015, 03:24 AM   #5
troek
troek's Avatar
bump
troek is offline
Old 09-03-2015, 01:37 AM   #6
FingR-S
I got sucked into boost..
FingR-S's Avatar
Drives: Whiteout FR-S & Supercharged BRZ
Oil Cooler
Hi, I'm interested in this unit. I need something to warm my oil up a bit quicker in the mornings and also keep it cooler for occasional track days.
Did you get readings on your oil temps when using it compared to stock? How hard was it to install?
Thanks!
Marc
For sale: 2013 BRZ Vortech Supercharged with nice updates.
Vortech Supercharger - Perrin exhaust - 245 RS3 on RPF1's
FingR-S is offline
Old 09-03-2015, 01:46 AM   #7
troek
troek's Avatar
Its pretty easy to install, hardest part being the lower radiator hose as you have to remove the aluminum tray under the engine. after that its pretty easy. drain your coolant, swap the hoses in, and bolt the cooler on, don't even need to drain your oil if you don't want. theres some pretty good DIY guides out there I can link to if you need. I don't have any temps for without a cooler(ive read some peoples went as high as 280), but with this cooler on tracks i saw 230-240, occaisonly it hit 250 on longer straits in the summer. It definitely helps warming the oil up, it seems to take forever now for me.
troek is offline
Old 09-03-2015, 12:50 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Thanks!
Marc
I have it on my car. I can still hit ~130C if I tried to heatsoak the car really bad, but usually on the warmest days I hit 125-126C max. Stock easily went 135+
Install is easy if you have replacement radiator hoses available, however the lower hose is the hardest hose to remove.
-alex
mav1178 is offline
The Following User Says Thank You to mav1178 For This Useful Post:
troek (09-03-2015)
Old 09-03-2015, 01:08 PM   #9
FingR-S
FingR-S's Avatar
Thanks for the info! Sounds like it will sufficient.
FingR-S is offline
Cusco Oil Cooler akuhei Forced Induction 126 08-19-2016 10:05 AM
FS Cusco oil cooler (water cooled) keen as Australia Classifieds 10 08-31-2014 01:25 AM
DIY Cusco Oil Cooler lazyluka DIY (Do-It-Yourself) Guides 11 02-27-2014 02:15 AM
Cusco oil cooler vs Perrin input please ft86me Engine, Exhaust, Transmission 0 10-08-2013 05:05 PM
New Cusco oil cooler ahaghshenas Engine, Exhaust, Transmission 11 04-02-2013 10:48 PM
